Question about Hotpoint HSS25GFP Side by Side Refrigerator
It stays on all the time. It is starting to create ice in freezer.
  • 525 Answers
Thermostat is died , replace it or call a technician who will help you
Posted on Sep 12, 2009
Leibherr freezer icing up and not staying at right temp
Probably the heating element in the defroster is not working
Mar 30, 2013 | Refrigerators
I have a GE GSH25JSTA SS refrigerator and the freezer makes ice very slowly and not fully formed ice; the water dispenser stopped working. I replaced the filter and the water used to dribble with the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | Refrigerators
What setting between 1-9 should I set Freezer to prevent freezer burn
Good day,
Freezer burn is due to too cold a temperature in the freezer compartment. Nominal for that machine is 4 to 5.
However only time will tell you what is acceptable, since freezer burn can occur even at a warmer setting, if the product is stored a long time.
1 is warmest and 9 is coldest. I would lean to a slightly warmer setting to start off but that will create a trade off, since it would reduce the speed of ice production, and with especially high quality ice cream, possibly ice cream being too soft.
Patience is your friend here. But what you want is there.
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer working only slightly. Refridgerator not working at all.
If you have ice build up behind the panel inside the freezer, you most likely have a bad defrost heater. You can remove the back inside panel of the freezer. Take a hair dryer and defrost the ice. When the ice is gone you can inspect the heaters. If they are not fixed it will continue to happen. When the coils ice over, first the freezer will get warmer. The first complaint is that the ice maker stops working. Then the ice cream starts melting (Due to the sugar in ice cream, it has to be around 0 degrees to stay froze solid). Then the fresh food section starts warming due to the fans not being able to force air into the fresh food section.
Please rate solution if helpful. Thanks
Aug 19, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Ice dispensor
Make sure that the "flapper-door" closes about 3 seconds after the ice dispenser button is released. Mine had a habit of catching and staying OPEN. This allows warm air to enter the dispenser / freezer compartment causing your problem.
If it is stuck you have to take the dispenser apart to loosen / lubricate the flapper door cam to allow for free movement.
This is the worst ICE system I've ever seen for a variety of reasons.
Jun 06, 2009 | LG LSC26905TT Side by Side Refrigerator
Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Jan 01, 2009 | Viking 42 in Built In Professional...
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
78 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
