Question about Whirlpool Dryers
Will not produce heat - Whirlpool Dryers
    Problem Solver:
  • 5 Answers
Element damaged
Posted on Sep 12, 2009
My gas fireplace..I only want to see the flame. I don’t want the heat at the moment. How do I do that
????? ah gas when lit will produce flame which also produces heat with gas you cant have one without the other ----only electric can you have a flame show and no heat and visa versa
Nov 07, 2017 | Heating & Cooling
Oil furnace only produces cool water intermittedly and only when heat is actively on
For clarity, a Furnace produces HOT AIR for heat while a boiler produces HOT WATER for heat. Just remember...boil = water. You said your "furnace" does not produce hot water for a shower and because furnaces do not product hot water unless they have some model that do???? Usually people with a furnace have a seperate hot water heater. People with boilers though can produce hot water for use as both their sinks/showers hot water and their heat (by heating water that goes through baseboards) in their house. I don't believe any furnaces produce hot water most of the time a furnace just produces hot air for heating. So figure out what you first have.
Having said that, I'll assume you have a boiler like I do and my Weil McClean(sp?) stopped working a while back and wasn't turning on to "boil" any water. I took apart the burner and there is a light sensing photo resistor as part of the controls. If this phto resistor goes bad, the boiler will not start. The resister is cheap, I think it was $8 but you have to know what you're doing to change it. So you may be better to call someone who can work on such equipment.
Boiler's themselves are not overly complex. Home heating oil is the same diesel fuel that you can buy in a gas station only the government has "oil" companies put a RED die in home heating fuel which is usually cheaper then Diesel fuel because diesel fuel is taxed to death. The reason they do that is so that if you try putting RED tinted home heating fuel in your truck and you get pulled over (because you're a trucker with and 18 wheeler and they typically do inspections of these trucks) you will be a huge fine if they see you're running home heating fuel and NOT paying your taxed by purchasing Diesel fuel. A little bit of background so you know the fuel you are dealing with here. So it's dieslel fuel without the tax you run in your boiler. Gasoline on the other hand is VERY explosive as you know, but diesel fuel (if you're ever tried to light it) takes some coaxing to get lit. When it's cold out, diesel fuel is very hard to light and that's why trucks use glow plugs. You don't need those in your home though.
But because diesel fuel/home heating oil is hard to light, it's sprayed as a msit into your boiler, so that it can light more easily.
But because it is a fuel, you should know what you're doing when messing with it. FInd out what you have, and then have someone work on the issue if you haven't already. I'm guessing you have had it fixed by now?
Mar 21, 2014 | Water Heaters
Soot produced by propane heating stove
If it is still producing soot two problems blocked burners burning yellow causes soot , or blocked injectors, or pressure to burners is wrong needs seting to correct pressure
Feb 07, 2013 | Heating & Cooling
110.c62692102 does not produce any heat
If it's not producing heat, then it's not working well.
If this is a gas dryer, you probably need a new ignitor.
Call a repairman who you can trust.
Sep 04, 2012 | Kenmore Dryers
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
No in car heating,blowers working fine but it wont produce heat. Its a 51 plate grand cherokee Thanks
If it won't produce heat then you have an issue with your heater core. The heater core could be bypassed, in which case no hot coolant will get to it to produce heat inside the cabin. The heater core could be stopped up with dirt/debris, in which case the heater core can't radiate heat to produce heat in the cabin. The ducting in the dash could not be allowing the hot air to flow to the vents - therefore no heat in the cabin. I'd start with the heater core and check to see if it is bypassed. This generally happens on older vehicles because the parts can be harder to find.
Nov 01, 2011 | 2001 Jeep Grand Cherokee
My dryer has power and tumbles, but produced no heat (tested with vent tube off). I reset the circuit breaker and now it produces heat. What is up?
If your dryer is clogged up this will not produce heat inside the dryer but will produce heat to the vent tube. Try unclogging the Vent tube and see what happens.
Feb 18, 2011 | Dryers
Hi, Does the dehumidifier produce heat or cool air? When I put mine on, the room becomes hotter.
Yes it will make heat in a room... the unit does not cool or heat but the compressor produces heat from it running...
heatman101
Aug 31, 2010 | Kenmore 54501 Dehumidifier
My dryer spins and heat just a little but not enough to dry any clothes
Need to change the heater filament. The heater filament has several portions to produce heat. As it ages, some portions are not producing heat anymore hence the total heat produced by an old filament can not put out as much as originally designed.
Jan 08, 2010 | Estate EED4300TQ Electric Dryer
No heat is produced when dryer is running. How
most likely the heating element is toast, remove and replace, inexpensive, second could be heat thermostat but unlikely
Aug 08, 2009 | Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
