I just bought this second hand set and donot know how to program channels from cable supplier. TV set stays on blue screen. What should I do.
  • nick_florea Sep 12, 2009
    tks it is a Jensen cr2006j 20" tv
  • 13,433 Answers
Send me the brand and model and I can look into it. can't help without the brand and model.
Posted on Sep 12, 2009
Goodmorning, bought a zenith tv didn't get the remote. Wonndering how i can programme it using just the buttons on the tv. How do i get the menus up. it only catches threes channels as of now.
Hello
There are two types Zenith TVs. One type will have "Menu" button on its front panel and other will not. If your Zenith is the first type, you can programme it without a remote control. If it is the second type, you must have a remote control hanset to programme it.
Programming method
First connect the TVs antenna socket at its back with external antenna or cable.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
menu.
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
tuner
Cable will not work unless you subscribe to a cable service
OK.
Jun 17, 2011 | Zenith H27E35DT 27" TV
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My Sharp Flat Panel Television LC19SB25U has Picture but No Audio
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Eric
Aug 16, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Only goes up to Channel 19.
Go into the TV's setup screen and make sure its tuning mode is set for "cable" (may say "CATV"). I'm not familiar with this set so I don't know exactly what the screen will say, but there should be some reference to channel setup, TV setup, tuning band, etc. It's probably set on "AIR" now.
Normally, when set for off-air reception, the set works properly for channels 2 through 13, and 14 up don't tune properly. Since you're getting channels up to 19, there may in fact be some kind of tuner problem. If the TV is already set for cable tuning, you may have found why the former owner was freecycling it. But check that tuning mode.
Apr 06, 2009 | Apex Digital GT2015DV 20 in. TV/DVD Combo
37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
Feb 21, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
JVC AV27020
ok,i'm sure your tuner is defective,what you will do is try to resolder the tuner if not effective replace it with a new one.blue screen in your tv means that your blue back setting is on,and couldn't pick up a signal
Oct 12, 2007 | JVC AV-27020 TV
Mono setting?
What channel is it and when they tune in that channel, is the picture nice and clear or is it grainy and snowy before the screen goes blue? On some sets, if the signal is weak, the picture will go blue. This is called Blue Screen and is there so you do not see very poor, grainy and snowy pictures. Some sets will have an option in the menu to turn the blue screen off.
Aug 27, 2007 | RCA 24F512T 24" TV
Set up an a Panasonic TZ-20L3Z
Press MENU button, select PRESET and then , select MANUAL PROGRAM and SEARCH, when search completed the program stops. Give the channel and store.
Aug 19, 2007 | Toshiba 27A34 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
