Kitchen Ranges
Problem for GE Kitchen Ranges
Generic problem for all GE Kitchen Ranges
Gas burners will not ignite
By hossdog on Sep 12, 2009
gas burners will not ignite ater cleaning stove top
Best Solution
posted on Sep 12, 2009
Very Helpful)
sivaranjini
Rank: Guru
Rating: 86%, 241 votes
hi friend,
On stove top burners that have sparklers that are not visible at the burner head, the burner heads have ignition ports. If the sparklers are functioning and the burners won't lite, chances are the ignition ports are clogged or restricted.
Ignition ports are tiny holes up one side of the burner head. If these holes are restricted, they must be cleared out. Cleaning can be accomplished using one of three methods.
Most commonly, a large sewing straight pin needle can be used. DO NOT enlarge the ignition holes. Doing so will have adverse burner lighting effects.
Burner heads where the flames will not burn completely around the entire circumference of the burner head, the holes which do not have flames are clogged up and need cleaning.
In cases of extremely dirty burner heads, soaking the burners in very hot water with plenty of dissolved automatic dishwasher detergent for several hours, rinsing and drying or a combination of both methods for heavily soiled burners.
hope this helps u
thank u for using fixya
please rate me..................
regards
sivaranjini
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kitchen Ranges
Questions and Unsolved Problems for Kitchen Ranges
Answer
is the maytag range mer7775ww a good buy?What are the complaints about it?
Answer
Answer
GE Spectra Electric Range....while oven was in use the electric element started arcing and burned... (More)
Answer
Bottom element not heating up
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Kitchen Ranges:
Top Kitchen Range Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Kitchen Range Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
