Question about Behringer Music
I have a pmp 5000 and i cannot get any volume from my monitors what do i need to plug them in to and how do i turn up the volume
  • Behringer Master
  • 5,603 Answers
Assuming you are using BOTH power channels for your main speakers, you MUST use external, additional, amplifiers for the monitors. There are ONLY two power amps in the PMP5000.
The other option is to run mono for the mains and use the second power amp (comes out on the Speakon connectors) to drive the monitors. For this, the little slide switch has to be on the middle position.
Doing this, you have to adjust the monitor volume controls for each strip.
Posted on Sep 12, 2009
2 Suggested Answers
  • 5603 Answers
SOURCE: i have a beringer eoropower pmp 5000. i run my
With the AB switch at the center position Mon1/Main you control the volumes INDIVIDUALLY with the MON pot for each input that is a couple positions above each of the input sliders.
Posted on Aug 27, 2009
How to set up a behringer pmp 2000
http://www.behringer.com/EN/Products/PMP2000.aspx
You will find the manuals on this web page under "Documentation"
May 09, 2014 | Music
Behringuer pmp 5000 turns off
Can you elaborate a bit more about what you mean by "turning off?" What are you doing up until that point? Does it do it at certain times, etc.?
Apr 12, 2014 | Behringer DJx700 5-Channel Pro DJ Mixer...
PMP 5000 blows fuse at start up
for a 220v 50hz 1000w the fuse is T 6 3 AH 250v
for a 100v 1000w the fuse is T10 AH 250v just make sertun thats wright or contact the manufacture address 18912 north Greek Parkway, suite 200 bothell, WA 98011 USA phone +14256720816
Nov 28, 2011 | Behringer Music
One side of my europower pmp 5000 is out, the other is fine.....what up?
What is up is one of the two power amps is blown... I know this problem... It is USUALLY the rearmost channel which goes to the left Speakon faacing the back. Weak insulation between layers of the multilayer circuit board arcs and fries three transistors and a diode and sometimes a few more components. It takes a lot of skill to restore the module and is beyond most repair shops. A whole new module costs about $155 from Full Compass. The amp is an HCA2400 module, but you MAY need the Behringer part number to order it from Full Compass. Also please read my tip on Fixya for PMP mixers regarding the hazard when using 1/4 inch plugs from the Speakon connectors... the Channel A sleeve is the "hot", not the tip and if you ground the sleeve, goodbye channel A...
Aug 18, 2011 | Behringer Europower Pmp5000 Powered Mixer...
We set up the monitors in our pmp 6000 at the mon send jacks but we didn't get any sound from it when we turned up the monitor volumes. What is the proper way to set them up?
I HOPE you know that the monitor send jacks are NOT powered. You MUST use either powered monitors or an external amp for these to drive speakers. Assuming you have done that, you have to turn up one or both of the monitor knobs for each channel you wish to send to the monitors at the desired level. Then you advance the monitor faders for the overall monitor level.
May 16, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Suddenly the monitor one output jack has no sound. If I turn the Monitor one slider all the way up I can hear a very low sound with distortion. The monitor output works fine.
Make sure the appropriate channel rotary knob MON1 knob is turned up for the channels you want into MON1. ALSO test other channels if they can be sent to MON1. The MON jacks are TRS with the tip as the hot and the sleeve as resistor to ground.
Hopefully you have used good practice and have ALWAYS powered whatever you are driving from the MON1 out from the same receptacle as the PMP5000. If not, ground bounce MAY have destroyed the driver in thee PMP5000. They USUALLY don't tell you these things in the user manuals, so it is up to us electricaal engineers to educate.
FIRST plug in a set of headphones and see if sound comes out (it will only be one side and fairly low volume, usually the left). If it does, then cabling and whatever amp you have for the MON1 has a problem. I have schematics and can help you troubleshoot a bit.
Also PLEASE read the tip I have posted on here about a grounding hazard of the A channel when using Speakon to 1/4 inch cables.
Nov 07, 2010 | Behringer Europower Pmp5000 Powered Mixer...
I'm not satisfied with the built in effects of my PMP 5000. Can I hook up an external effect and if so,how.
Depending on whether you want the external effects to be on everything or just a single mic input, you connect them to the power amp "insert" or the insert for the mic you want it on.
Looping it out on multiple mics would be tricky, but you could send the units effects into one of the monitor outputs only by selecting a "non-effects" setting in the unit and sending internal effects to one of the monitor outs, and then looping it back into another input to join the mix.
Aug 23, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I HAVE A BEHRINGER PMP POWERRED MIXER 5000,I LOST ...
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} tries websites like Shopjimmy.com,Ebay.com to buy parts for the replacement.
Good luck..
May 21, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have a beringer pmp 5000. Out of the box, I
Yes, the fan is temperature controlled. You have to drive it a bit before it runs, and then it is kind of throttled versus temperature.
Sep 20, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
I have a beringer eoropower pmp 5000. i run my mains and monitors in mono how do i turn the volume up for my monitors
Aug 26, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Music Logo
193 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
