Question about Sharp UX 300 Plain Paper Thermal transfer Fax
Paper won't feed through to send
My Sharp UX 300 indicates that it is "Ready to Send" after I have loaded the three sheets of material that I'm trying to send. It dials the number, shows that it is "Sending" - and then finally gives me one beep...but none of the sheets have fed through the machine.
Please help!
  • T.L. Sutton Dec 11, 2007
    Hey, Trickieone -
    Thanks for the suggestion, but I fear that the whole thing is my error in the first place...Looks like the phone hookup isn't working; I don't get a dial tone! If I'd noticed that in the first place, I'd never have gotten so far as to request assistance with what was obviously not the actual problem. (I've never used this fax machine before so assumed, when it made appropriate 'dialing noises,' that it was working but just not feeding the paper. Wrong!)
    Sorry about that.
    SundownLF
    Novelist:
  • 208 Answers
I would suggest taking a soapy type cleaner such as fantastic and cleanign all the rollers in the scanner.
Sounds like they are slipping. May have to clean them a few times to get all the contaminants off.
Sounds to me like thats your problem.
The rollers may be worn. But try cleaning them thorouly.
Posted on Dec 11, 2007
  • Rick Kasper Dec 11, 2007
    Is the white retard pad that puts pressure on the paper worn out?
    It is just inside the scanner before the white roller. It should be about 3/4 of an inch long. If it is worn to little nubs that will caus a no feeding problem also.
    It is a white U shaped pad in the top portion of the scanner.
    Thats ok. But yeah, it will make the tones, as if dialing.
    But the one thing you don't think to listen for is a dial tone.
    You are correct, you will suspect it is working properly.
    No problem, Glad its working.
Copy from computer to Sharp ux300
The UX-300 is a fax/copier. It can send and receive faxes over a telephone line and it can make copies of paper documents. It is not designed to connect to a computer.
If you need a manual you may download a copy at
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/fax_man_ux300.pdf
Apr 23, 2013 | Sharp UX 300 Plain Paper Thermal transfer...
Sharp fax machine ux b20 won't display ready to fax. Can not send a fax
I called Sharp and they said if the paper was feed properly (and it was), then the problem is with the fax sensor and the machine needed to be serviced
Aug 20, 2009 | Sharp UX B20 Plain Paper Inkjet Fax
Send and receive
Most likely has a problem with the fax PCB board inside it. Its not worth repair.
Jan 07, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
Sharp UX-105 Fax
We assume you have loaded the thermal paper into the machine and hooked it7108C8H up to your phone line; then, for a free manual go to: http://www.gmfok.com/manuals/faxes/sharp/_ux-105.html
Sep 20, 2017 | Sharp UX B700 Plain Paper Inkjet Fax
Material I'm trying to send doesn't 'feed'
does it try to grab the paper?
do you hear anything happening before the beep?
The machine recognises that there is paper, then you should hear the communication, once it has the correct signal telling it the line is available for transmission it will feed the paper.
look at the tires and see if they turn to feed the paper, is there something in the way, do the tires turn,???
if yes clean with alcohol and try again, if the tires are too smooth then they need to be changed.
Dec 11, 2007 | Sharp UX 300 Plain Paper Thermal transfer...
Fax Machine Jams Everytime I Try to Load Paper...
Is it jamming at the document feeder, or in the blank paper tray? You may need to clean the feed rollers. Use a lint-free cloth (not paper) and some alcohol.
Dec 27, 2006 | Sharp UX-B20 Plain Paper Inkjet Fax
Sharp UX 300 Plain Paper Thermal transfer Fax Logo
85 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
