Question about Gateway FPD2275W LCD Monitor
I have a Dell monitor and the text is blurry and fuzzy, how do I fix this?
    Scholar:
  • 44 Answers
This is actually from dell support website.. hope it will correct your problem...
1 Ensure the correct resolution is set for the monitor. Flat panel monitors display the sharpest, clearest images when set to their optimal resolution. Sometimes games and other programs will change the resolution then fail to set it back once they are closed. This will then make the desktop look big, distorted, and grainy. Perform the following steps to adjust the resolution:
  1. Right-click an empty area of the desktop, and then click Properties. (Or, click Start, click Control Panel, and then double-click Display.)
  2. In the Display Properties window, click the Settings tab.
  3. Under Screen resolution, move the slider to the desired setting. For most flat panels the optimal setting will be all the way to the right.
  4. Click Apply, and then click OK.
  5. If prompted, restart the computer.
NOTE: If the resolution will not adjust to the appropriate settings, the video driver may need to be reinstalled or updated.
2 Ensure the screen is clean. Finger prints and smudges will make the screen look blurry. Clean the screen with a soft lint free cloth. If needed, dampen the cloth with warm water or use a LCD cleaning kit that can be purchased from most electronics stores.
3 Use the On Screen Display (OSD) on the monitor to select the Auto Adjust feature. Selecting this will synch the video signal and can sharpen the video image.
4 Reseat the video signal cable to ensure a secure connection.
5 Use the On Screen Display (OSD) on the monitor to select the Factory Reset feature.
6 Test the monitor on another computer or test another monitor on this computer. If available, testing different hardware will isolate if the problem stays with the computer or monitor
Posted on Sep 12, 2009
3 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Posted on Jul 04, 2009
  • 5 Answers
SOURCE: Monitor display is blurry, with shadows and waves next to text
Jnanda,
Could be one of two related situations both have to do with built up magnetic flux:
!. If you have used the monitor for a significant amount of time and have never degaussed it that might be it.
To fix: Go to where your monitor's controls are (eg screen size/position, Brightness, Contrast, etc.). Providing that we are referring to an older style monitor (like a TV) and not a flat screen, you should find a degaussing button located there. This button is marked with a depiction of a horseshoe magnet. Press it.
If you have on screen settings control, hit the menu button and select the icon that looks like a horseshoe magnet.
You'll hear a buzz and the screen will go kooky for a moment.
You're then degaussed. Your problem should go away.
2. You may have moved the monitor close to a source of electromagnetic interference (or vice-versa) this will also cause that sort of thing you describe (remember that there are electrical lines in the walls (another source of EMI)
In that case move the monitor away from the EMI source or move the EMI source away from the monitor.
Remember that it could be both 1 and 2. So if the problem lessens but does not go away fully try both steps.
Posted on Feb 06, 2009
Fuzzy text
You need to test the DVI port and use the DVI-VGA adapter if your computer does not have a DVI port.
Dec 25, 2013 | Dell ST2210 21" Monitor
My computer screen is fuzzy and blurry, how can i fix?
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
don't forget to vote
Feb 20, 2011 | Dell Computers & Internet
Top left hand corner is fuzzy
I HAVE AN OLDER HITACHI 53" PROJECTION TV THAT IS BLURRY IN THE UPPER RIGHT AND LOWER LEFT CORNERS. IT LOOKS LIKE THE TEXT IS OVER LAPED WHEN PLAYING MY PS3. IT MAKES IT HARD TO READ. THERE IS NOT ANY PROBLEM WITH COLOR, JUST BLURRY. HOW CAN I FIX
Sep 05, 2010 | Hitachi 50UX57B 50" Rear Projection...
Fuzzy text
Try adjusting the Font Smoothing effect in the display properties. Windows XP http://support.microsoft.com/kb/306527
Nov 28, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Blurry Copies on Xerox WorkCentre C2424
There are three typical reasons for fuzzy text
1. Y-axis drum rotation problem.
2. Wrong drum temperature.
3. X-axis movement problem.
Sometimes the y-axis encoder will get oil inside and confuse the sensors, causing fuzzy/blurry print.
Most likely the drum assembly will need replaced.
Dec 03, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Scan views fine; prints fuzzy
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Nov 19, 2008 | Brother MFC-7820N Printer
Re: CTX monitor getting blurry
Hi Beth,
Your focus screen network turn faulty. It can be solved by by passing the original focus screen network to a new assembled focus screen network.
Apr 08, 2008 | CTX PL 9 19" CRT Monitor
Blurriness/Fuzziness
Hi, Using the OSD, select the Auto image adjust.
Sep 15, 2007 | ViewSonic VA703B LCD Monitor
Gateway FPD2275W LCD Monitor Logo
3,591 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
