Question about Sharp AR-M205 Black and White Copier
Repeated paper jams. can open side slide out and remove paper. can we pull rack it is going into? looks like it move green tabs either side, but does not release hot roller assembly. toner tray slid out front ok, but along side toner feed mech w/handle will not slide out front/afraind to pull to hard.
    Guru:
  • 389 Answers
I have a Service monual. I cant to send a PDF from here?please send me a letter to Email goodgold@inbox.ru Sergey
Posted on Sep 13, 2009
Brother MFC-9140CDW displays that I must slide the green tabs on the Drum units to get the printer to print as it jams. Did that -No solution
If the printer is jamming paper there are three things to check/clean. First make sure paper is DRY as is will hold up 16% weight in water from atmosphere. Second - clean the pickup and feed rollers at the end of the paper tray with alcohol to remove dust and oils. Third set all the drum cleaning tabs to side with the triangle. When you have done that try a print or copy. If the sheet jams pull it out backwards slowly and examine the leading edge. This will show where the jam is occuring and then you can trace the paper path to find any foreign objects (paper fragments) and remove them
Dec 05, 2014 | Brother Office Equipment & Supplies
Remove upper rack
When you pull the upper rack forward, the two metal glides on each side move forward. On the end of each glide is a white plastic end cap. If you look through the rack to the inside of each glide, you can see that the upper part of the end cap has a upper tab. I put my thumb on the end cap then press the upper tab forward with my index finger. Then press upward with your thumb and the end cap should slide totally upward and then out of the glide. Once both end caps are removed, the upper rack slides fully out of the washer.
Jan 25, 2014 | Whirlpool Gold 24 in. Built-In Dishwasher...
Unable to print 70
  1. Open the Outer Back(Rear) Cover (1) at the back of the machine. Pull the jammed paper out of the machine.
  2. Close the Inner Back(Rear) Cover (1) if it is open as shown in the illustration.
  3. Close the Outer Back(Rear) Cover. Make sure the cover is closed properly.
  4. Pull the paper trays (1) out of the machine.
  5. Push the two green levers up on both sides.
  6. Pull out the jammed paper (1) and press Stop/Exit.
  7. Push the green duplex unit up.
  8. Reset the machine by lifting the scanner cover from the front of the machine and then closing it.
    If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
  9. Using both hands, use the plastic tabs on both sides of the machine to lift the Scanner Cover (1) into the open position. Make sure that there is no jammed paper left in the corners of the machine under the plastic covers.
    Note
    • If ink gets on your skin or clothing immediately wash it off with soap or detergent.
    • If the paper is jammed under the print head, unplug the machine from the power source, and then move the print head to take out the paper.
    • If the print head has stopped in the right corner as shown in the illustration, you cannot move the print head. Press Stop/Exit until the print head moves to the middle. Then unplug the machine from the power source, and take out the paper.
    1. Gently close the scanner cover using the finger holds on both sides of it as you push down on the Scanner Cover Support (1).
    Caution Be careful not to trap your fingers under the scanner cover. Always use the finger holds provided on both sides of the scanner cover when opening and closing it.
    1. Push paper tray #1 and paper tray #2 firmly back into the machine.
    Note Make sure you pull out the paper support until it clicks.
Nov 11, 2011 | Brother MFC-6890CDW Printer
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Paper jam
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 07, 2010 | Office Equipment & Supplies
Paper jam light on permanently, printer is jammed
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 25, 2010 | HP DeskJet 970cxi InkJet Printer
Paper Jam {Printer does not detect paper
Nov 18, 2010 | Office Equipment & Supplies
How do I remove a paper jam? The paper is
The following is general advice that applies to removing paper jams in most printers, copiers, etc.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab.
Always remove jammed paper by pulling it in the direction of normal travel only. Don't try to pull it out against the direction that it entered the printer. Sometimes rollers inside the machine have a knob (usually coloured green or orange) that can be used to manually wind the page through the printer or fax. Always turn in direction of arrow indicated only.
After removing page, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test
Feb 04, 2010 | Brother IntelliFAX 4100 Laser Fax
My oki printer b430dn is flashing 380 paper jam but cannot see any paper, have removed toner and looked inside but still no joy
Hi
You have to look under the cover remove the black plastic cover, Remove in the left side by sliding the litte plastic tab in to the mittele and gently pull up, when it is loose in the left side slide it on to the mittle and it will go of in the right side too, Now remove the next black plastic cover, it's all black with at little "sharkfin" i the center, Just pull genltly upwards, and under there is the "380" It is at little tab, just wrikele it a few times. Now just assemble the printer an you are good to go
Oct 27, 2009 | Oki Electric Industry B430DN Laser 30PPM...
Paper jam
A paper jam is when paper feeds badly (ie: skews, crumples, gets caught, etc...) in the printer mechanism and stops the flow of paper through the system.
The first thing you need to do is get rid of the paper that's jammed everything up... To do this you'll need to:
  • Open the printer lid (lift the lid by placing your fingers under the control panel lip and carefully lifting upwards)
  • Remove the rear panel (press the two grey buttons/tabs inwards to release the panel)
In each of the areas you expose you will probably find some paper which has started feeding and then stopped.
IMPORTANT: DO NOT Yank or otherwise pull the paper out in an abrupt fashion as this can and often does damage the printer feeding mechanism..
The best way to remove a jam is to try and pull the paper out in the same direction as it would normally feed ie: straight out.. Pulling to the side is not a good move... It takes a little bit of time but also look for ink soaked pieces of paper which may lie doggo and hidden as they will cause other problems in the future.
You may also want to get the printer to move the printhead over to the left side by pressing and holding the OK button (on the control panel) as if you were replacing the printheads and see if the printhead has ripped any paper off into the parking area (far right).
Once you've done all that and made sure there's no paper or bits you can replace the rear panel and close the lid and you should be good to go...
If the problem repeats, look for foreign objects where the paper bunches up and also make sure that your paper guide (the moveable part in the paper tray) has been moved into position to guide the paper properly (ie: not TIGHT against but not looser than a 1mm or so).
Hope that helps.
Martin
Mar 11, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Sharp AR-M205 Black and White Copier Logo
62 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
