Question about HP 530 Notebook PC
Does it have bluetooth - HP 530 Notebook PC
    President:
  • 987 Answers
Yes it has bluetooth
Posted on Sep 12, 2009
To set up bluetooth
How can I hook up my XO vision X348NT Bluetooth to my phone?
Jul 01, 2011 | Computers & Internet
Tip
How to turn Bluetooth on and off on a BlackBerry Tour
The BlackBerry Tour comes with Bluetooth capability, but in order to connect to a Bluetooth device, you have to enable the Bluetooth functionality. When you're not using a Bluetooth connection, disable Bluetooth to avoid other devices from connecting to your BlackBerry.
- To turn Bluetooth on:
From the main home screen, press the BlackBerry button (to the left of the trackball) to go to your Home folder. Scroll down until you see the antenna icon for Manage Connections and click on it. A pop up list will appear; find Bluetooth on the list and click it to put a check in the box next to it. "On" will appear next to Bluetooth, and the Bluetooth icon will be displayed in the upper right corner of the screen. Your BlackBerry is now in Bluetooth mode, where it can connect and pair with other Bluetooth-capable devices.
Bluetooth can also be turned on from the Options folder, under the Home folder. Select Bluetooth from the list and when the screen comes up saying "Bluetooth: Disabled," press the BlackBerry button and then select Enable Bluetooth. If you've previously paired your Tour with other Bluetooth devices, the list of those devices will appear.
- To turn Bluetooth off:
From the home screen, press the BlackBerry button. Scroll down to Manage Connections and select it. In the list that appears, click Bluetooth to uncheck it and disable Bluetooth functionality.
You can also turn Bluetooth off by clicking Options in the Home folder, selecting Bluetooth from the list of options, then pressing the BlackBerry button and choosing Disable Bluetooth.
on Jan 14, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Trying to connect jabra BT2080 to phone. says enter passkey?
  1. Bluetooth device A looks for other Bluetooth devices in the area
  2. In order to find other Bluetooth devices, Bluetooth device A must be set to discoverable mode. When set to discoverable, Bluetooth device A will allow other Bluetooth devices to detect its presence and attempt to establish a connection.
    You may set your discover setting off if you like (It is recommended that you turn it off when not using the Bluetooth). When the discover setting is off, no other Bluetooth device will be able to find it. Undiscoverable devices can still communicate with each other but they have to initiate communication themselves.
  3. Bluetooth device A finds Bluetooth device B
    Usually the discoverable device will indicate what type of device it is (Such as a printer, cell phone, headset, etc.) and its Bluetooth device name. The Bluetooth device name is the name that you give the Bluetooth device or the factory name that originally was programmed.
  4. Bluetooth Device A prompts you to enter a password (PassKey)
    With advanced devices (i.e. computers, smartphones), both users must agree on the Passkey and enter it into their device. The code can be anything you like as long as it is the same for both Bluetooth wireless devices.
    On other devices, such as Bluetooth headsets, the Passkey stays the same. Refer to the product's manual for the default passkey. Most often, the default passkey is "0000".
  5. Bluetooth device A sends the Passkey to Bluetooth device B
Jan 26, 2011 | Jabra BT2080 Bluetooth Headset
Want to hook uo bluetooth
First switch on bluetooth (settings---bluetooth).
Start > Settings > Communications and Add new Bluetooth headset. htc will search bluetooth headsets and find it. it will ask you to enter bluetooth passcode, usually it is 0000. then finished and you have paired Bluetooth headset with HTC
Mar 26, 2010 | HTC Cell Phones
How do i turn on the bluetooth on my netbook msi
Is it equipped with bluetooth? Do a search for bluetooth on your computer and it should bring up the bluetooth icon. Go "start", "search", then "all files", and type in bluetooth and search.
Oct 29, 2009 | MSI U100-422CA Notebook
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Bluetooth
my bluetooth device not working. if i try to start it laptop say NO BLUETOOTH DIVICE.so what can i do?
Dec 12, 2007 | Acer Aspire 5100 Notebook
HP 530 Notebook PC Logo
344 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
