My machine will not switch to rinse cycle. - Washing Machines
    President:
  • 1,776 Answers
This could be a timer issue or a cold water supply issue, since cold water is what's used in the rinse cycle. You didn't say if the machine attempts to fill when it gets to the rinse cycle or not, but first check the water inlet valve (especially the cold water side). Remove the water supply hoses and check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 12, 2009
Machine goes into extra rinse cycle
This may seem obvious, but have you set the rinse cycle indicator switch to one or two rinse cycles? If to only one, then try move switch back and forth between one and two a couple of times to ensure that you have good contact with ONE rinse cycle.
Sep 04, 2014 | Washing Machines
Model 9156200 top loading washing machine
the lid switch may be loose or broken it happens to me it was washing but never rinse i found out that it was a loose switch this switch prevents the rinse cycle from working with the lid open because of the high speed rinse ,some machines dont work at all, a loose switch makes the machine think the lid is open even if it is closed.good luck.
Apr 16, 2014 | Kenmore Washing Machines
Kenmore 70 series wahing machine wont start rinse cycle
Have you tried the rinse cycle in every wash cycle selection on the dial. Some times after using one particular dial setting all the time the contacts on the switch get corroded or burnt out, if the rinse cycle works in other settings on the dial then this is most likely the problem. You can then look up on line and order a new switch for the unit usually takes about two weeks to get in and is fairly easy to replace.
Aug 26, 2012 | Whirlpool Washing Machines
Water level on rinse is to low, on wash cycle the water level is good, I think maybe three quarts of water come in for the rinse cycle, please help. brand new admiral model # ATW4475XQ
this machine has a water level switch for the wash cycle and a switch for the rinse ccycle. remove control panel and take a small screwdriver and rotate the lever on the rinse cycle switch 1 click. (the rinse cycle switch is the one that does not have the knob on it. Unplug the machine before this is done. You will now have a full tub of water for the rinse cycle.
Jul 24, 2011 | Admiral Washing Machines
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Rinsing cycle won't START
After all, I turned machine off with power switch, waited 30 seconds and turned it back on. It displayed "RINSING CYCLE" message, but this time went through regular rinsing cycle, then rinsed thoroughly (I counted several cups of water) and RETURNED TO NORMAL.
Halleluiah! Now I can get my morning coffee again!
Aug 30, 2008 | Gaggia Titanium Espresso Machine
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
