Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
Trying to replace ext spring on lawnflite 548 can't get the spring to stretch the last inch.
  • 389 Answers
You don't specify which spring but if you take a piece of starter cord, tie it in a loop and hook it on the loose end of the spring, put in a long screwdriver, a piece of broom handle or anything similar, it will give you a lot more leverage to pull the spring. Once you get it to where it needs to go, you can maneuver it to get it hooked then just cut the rope and pull it out
Posted on Sep 15, 2009
Mtd lawnflite 548 how to fit drive belt
Contact MTD if your manual doesn't cover this, or buy a shop manual
Aug 09, 2014 | Mtd Garden
Craftsman tractor 917.273241 25hp Kohler, 48" cut. The clutch return spring will not hold tension more than a few hours of cutting. The temper in the spring end near the exhaust pipe from the engine to...
I'd be tempted to shield the spring from the heat of the exhaust - is there any way to pop rivet on a piece of aluminium sheet and bend it to not impede the operation of the clutch?
Aug 08, 2013 | Craftsman Garden
The govenator spring fell off my push mower
make sure not to stretch it out this is critical under filter houseing is the throttle useally white plastic on a shaft going down through carb and has a hole or 2 one for governer rod and the other for the spring then a tab a inch or so away with a hole carefully hook into the metal tab and carb with out over stretching the spring
Sep 05, 2012 | Mtd 22" Yard Machine Push Mower
Tighten belts on my Yard machine ride on lawn mower
There is rarely any adjustment to tighten the belts on a riding mower. The belts are tensioned by an idler pulley which is controlled by a idler pulley spring. Almost all riding mower belts must be accurate to the hundredth of an inch or no less than accurate to 1/8th inch. It is very rare for a belt to be in full inch increments. This is why automotive or general purpose belts will not work on a riding mower. I know it is tempting to try to get by with a $10 belt rather than spending $35 or more for the correct belt. Trust me, you will only waste your money trying to get by with the inferior belts. Riding mower belts and extra heavy duty and generally will not stretch at all. Generally they will have 5 or more strands of a Kevlar type material so that stretching is virtually non existent. If the belt will not tighten then it is most likely not the correct belt. If the belt is in fact the proper belt and still is too loose, then you should look for pulley wear or weak tension springs. Metal pulleys do wear and tension spring do loose tension.
Sep 12, 2009 | Mtd Garden
HP 640 Fax...can't recieve faxes
You cannot use a four wire cable to connect the fax to the wall. You must use a two wire cable, like the one that came with the machine.  BTW, that means you can't you the EXT port to connect a two line phone or answering machine.
Sep 04, 2008 | HP 640 Inkjet Fax Machine
BOSCH WASHING MACHINE RETAINING SPRING FOR FRONT DOOR GASKET
This is a two person job. The spring part of the metal ring goes at the 6:00 position (note the groove on the metal part of the machine). Fit the ring into the gasket as much as you can on the hinge side. While one person uses pliers to stretch the spring, another person uses a flat head screwdriver to move the ring into the gasket groove. The trick is to stretch the spring as straight and close to the machine as you can or else the ring pops off and the gasket has to be reset.
Aug 01, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Changing rear drum brakes ona 1999 chevy dually
INSTALLATION PROCEDURE
  1. Install the parking brake lever (2).
  2. Install the spring washer (3). The concave side of the spring washer should face the parking brake lever.
  3. Install the pin (4).
  4. Install the retaining ring (16).
  5. Install the adjuster pin (12) in the shoe (15) so the pin projects 6.8 to 7.0 mm (0.268 to 0.276 inch) from the side of the shoe web where the adjuster actuator is installed.
  6. Apply brake lubricant or equivalent to the threads of the adjuster screw (14) and inside diameter and face of the socket (7). Adequate lubrication is achieved when there is a continuous bead of lubricant at the open end of the adjuster nut (10) and the socket (7) when the threads are fully engaged.
  7. Install the upper return spring (5).
    • Lay the shoes (1 and 15) on a clean, flat work surface in the position they will be in when installed on the backing plate.
    • The shoe with the parking brake lever goes to the rear of the vehicle.
NOTICE: Do not over-stretch the upper return spring. Damage can occur if it is stretched to more than 204.2 mm (8.04 inches) .
  1. Install the adjusting screw assembly.
  1. Lubricate the shoe pads on the backing plate with a thin coat of white lithium grease.
  2. Install the shoe and lining assemblies (1 and 15).
  3. Install the upper return spring (5).
  4. Install the adjusting screw assembly.
    • Do not damage the wheel cylinder boots.
    • Overlap the bottoms of the shoes so the upper shoe ends clear the wheel cylinder boots.
    • Make sure the upper shoe ends rest on the wheel cylinder piston ends.
    • Do not place the lower shoe web ends under the anchor plate until the lower return spring is installed.
NOTICE: Do not over-stretch the lower return spring. Damage can occur if it is stretched to more than 107.3 mm (4.22 inches) .
  1. Install the lower return spring (6).
    • Bring the ends of the shoe and lining assemblies (1 and 15) together over the anchor plate.
    • Hook the spring ends to the shoe web holes.
    • Spread the lower ends of the shoe and the lining assemblies to clear the anchor plate.
    • Position the shoes against the backing plate and release them.
    • Pull the spring into the groove at the bottom of the anchor plate.
  1. Connect the hold-down pins and the spring assemblies (8).
  2. Install the adjuster actuator (11) over the end of the adjuster pin (12) so the top leg engages the notch in the adjuster screw. NOTICE: Do not over-stretch the actuator spring. Damage can occur if it is stretched to more than 83 mm (3.27 inches) .
  3. Install the actuator spring (13). The free end of the adjuster actuator (11) must engage the notch of the adjuster nut.
  4. Connect the parking brake cable to the parking brake lever (2).
  5. Install the drum. Align the marks made during disassembly.
  6. Adjust the rear brakes.
  7. Install the tire and the wheel. Align the marks made during disassembly.
Jul 21, 2008 | 1999 Chevrolet 3500
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
311 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
