No power on main switch, or the blue light in front
I've had my brand new Olevia 542 in storage for over a year. I decided to finally use it 3months ago. It was working fine for 3months. Then one day, it just wouldnt turn on. Tried unplugging it and still no luck.. I suspect a faulty power supply FSP271-4F02. Is there anyway I can have my power supply repaired? Is it worth still getting it fixed? Because getting a new PS is already a quarter of a cost of a bnew LCD.
  • 525 Answers
Yes , in TV repair shop
Posted on Sep 12, 2009
Olevia 542-b11 LCD HDTV won't turn on. Blue light blinks twice
My Olevia 42" television is several years old. In March of 2012, the infamous "TV will not power on" problem started.
The blue LED light on the front of the TV would go off for a split second, then light up again. The television would not start.
If you are handy with small tools and a soldering iron, you can change the capacitors on the power supply. My Olevia is a model 542-B11.
I bought the repair kit off eBay from seller: sghill99
As of this writing, the seller has sold 37 of these kits. The title of the auction is: Repair Kit, Olevia 542-B11, LCD TV, Capacitors
And if the url is still active, it is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230554940338&ssPageName=ADME:L:OC:US:3160
I made the repairs in March 2012 and it is now August 2012 and the television is still working great. It is turned on and off several times every day.
Oct 25, 2011 | Olevia LT42HVi 42 in. LCD Television
My olevia 42 in power doesnot come on. blue light was on when I pushed power to turn on tv. Blue light went out but tv did not come on. Blue light didn't not come back on. Television was working good. I...
You may be aware that Olevia is bankrupt and apparently Emerson bought the leftovers and is offering service but no parts sales.
I found this thread discussing antoher model's various problems but I believe your power supply has likely failed.
Olevia thread
If it is the type of failure related to the switched-mode power supply, these can be repaired by a properly equipped tech; I've done hundreds of them while still in business (which I am no longer).
Dec 07, 2010 | Olevia LT42HVi 42 in. LCD Television
Olevia LT26HV LCD TV won't turn on
Olevia has problems with the power supplies. Best solution is to remove the back of the TV. On the 542 it is about twenty number 1 phillips head screws. locate the power supply connectors check the board for the voltages, clearly marked on the PCB. Continue to check the voltages by powering on the Television. all voltages should be within its described range. If a voltage is low or nonexistent, the power supply is bad, usually a bad capacitor.
There are three series of caps, on the low voltage side it is 16 volt, next 24 volt and finally 36 volt (these are just max ratings.
which ever power that was found low the cap would be near that voltage output connector.
next step is to remove the board and replace the capacitor, using a soldering iron and making sure to solder with no slop.
with the board on an insulated (nonconductive surface connect the board to the televion. Check voltages and if no other voltage issues reassemble.
Jul 30, 2009 | Olevia LT42HVi 42 in. LCD Television
I have an olevia tv model number 542-13-11 and it will not turn on. Any suggestions would be appreciated. lindafranks@hammondhenry.com
do you get a blue light on ? if you do that means you have power so..it could be the main-board is bad on the television. But if you have no blue light on the front of the television then you have no power. You could try switching the power switch on the back of the television several times and see if you get any type of blue light on the front of the tv. If you don't then try connecting the power cord to a power strip or straight to the wall.. if you still don't get power try disconnecting the power cord from the television overnight and then plug it back in and see if you get any sign of power.. if still no sign of power then the television power supply is bad and will need to be replace or repair..
Since the manuf. of OLEVIA is out of buss ..you have this 3rd party repair center that is able to provide you with a repair quote call this number 866-965-3842 the company is called Amergence Technology who is able to repair and service all OLEVIA HDTV products..
Jul 21, 2009 | Olevia LT42HVi 42 in. LCD Television
I have an Olevia 542-B11 TV with remote control. I have Directv and always had to use (2) remote controls. My dog chewed my Olevia remote control, now I can't turn the TV on or off, adjust volume, switch...
its hard to find a remote that will work an olevia , since this brand is new and alot of manf. that make universal remotes have not updated there system..
This company called Amergence Technology sells the Olevia Remote and will control any olevia television.
Contact them at 866-965-3842 (just ask to purchase a remote)
Jun 29, 2009 | Olevia LT42HVi 42 in. LCD Television
Olevia 332h comes on for a few minutes then turns off
I have the same problem with my Olevia 332h. The TV shuts off after 10 seconds. I decided to wedge a desk fan in between the wall and the back of the TV. It worked! The TV doesnt shut off anymore. This problem is obviously heat related. I hope this information helps you.
Jun 03, 2009 | Olevia LT23HVX 23 in. LCD Television
Olevia 337 B11 Power Problem
Olevia sugested repl. the Main board
Mar 05, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 32" LCD HD TV model 232-S13
I have had the same problem with my daughters Olevia...232-S13 out of the blue ti just decides to not turn on...blue light lit where the on/off button located but no sound and no picture....i guess the saying "you get what you pay for" stands clear here.......very upsetting.....
Jan 12, 2008 | Olevia LT32HVE 32 in. LCD Television
Televison & Video Logo
254 people viewed this question
Top Televison & Video Experts
Electro Med Services...
