Question about GE Ovens
GE profile lower oven does not turn off...maintains low heat with the convection fan on for several hours.. When i turn oven back on and then off it stops...but the problem continues to happen periodically
  • GE Master
  • 5,323 Answers
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
Posted on Apr 17, 2015
  • 87 Answers
SOURCE: convection fan not working
Check for a bad fan motor or a jammed blade.
Posted on Jun 14, 2007
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
MNTECH
  • 1543 Answers
SOURCE: Lower element on GE Profile electric convection oven went out
Although this is an easy repair, the element is not a real common one so many service / parts stores may not have the WB44K5018 in stock. Make sure to get on finding one fast to make T day go smoothly. Here in the midwest I use C.E. Sundberg for a lot of my parts, as they have a good stock and are fast. (they have this part on hand at their main branch in Chicago and at Omaha, Fargo, and St. Louis Park (MPLS). The repair is essentially: Turn off power. Remove two 1/4 inch hex head screws. Pull element forward a couple inches into oven cavity to access the electrical terminals. Remove push on wires from old element. Install new element. One of the easier repairs.
Posted on Nov 23, 2008
SOURCE: Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Posted on Jan 04, 2009
jyackle5
  • 8197 Answers
SOURCE: installing ge profile double oven
You must use a three-wire, single-phase A.C.
208Y/120 Volt or 240/120 Volt, 60 hertz
electrical system. If you connect to aluminum
wiring, properly installed connectors approved
for use with aluminum wiring must be used.
That means that you ned a double 40 amp breaker.
Good Luck
Posted on Jan 18, 2009
I have a GE microwave/convection oven that the lower oven wont heat, fan comes on top microwave works but the oven wont heat
First reset your breaker, then check your wiring in the back of the oven. You may have just a wire loose.
Feb 24, 2013 | GE Profile JT965 Electric Double Oven
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
GE Profile convection with light bulb burning out
Multiple possibilities.
  • Being used as a night lite. (continuous use)
  • Not using a light bulb designed for use in a oven.
  • Inexpensive bulb. (very low lamp hour rating).
  • Oven door slamming.
  • Over voltage condition.
  • (My favorite) Light bulb swapping Gnomes.
Please take the time to give this solution a fix ya rating.
clarkco
Feb 22, 2009 | GE Profile JTP18 Electric Single Oven
Top oven doesn't heat.
We had this same problem in our lower oven and found the solution the night before Thanksgiving. With 26 people coming for dinner, I desperately need both ovens. (Turn off the breaker for the oven before you do this.)
My husband took the control panel off of the upper oven and found a wiring diagram. In the text, it said there was a manual reset for each oven in the access panel for each one. He opened the access panel for the lower oven and found the reset button in the middle of that area. He said it was a black circle with a red button in the middle. After reseting, we turned the breaker back on and everything works great!!
Nov 23, 2008 | GE Profile JTP56 Electric Double Oven
Cooling and/or convection fan
I had the same problem. The screen protecting the fan bends into the fan from the heat. Take off the top front control panel (3 screws), reach in to the back where the fan is and push the screen back away from the fan. As always, turn the power off first to avoid shock. This should solve your noise problem.
Apr 08, 2008 | GE Profile JTP18 Electric Single Oven
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Convection fan not working
Jan 01, 2007 | GE Profile JK915 Electric Single Oven
Ovens Logo
167 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
