Question about EnGenius EOC-3220 (EOC3220)
I can not log on to the wireless again
I can not log on the wireless again
  • hcsr
    hcsr May 11, 2010
    please can you give more detail, what have you tried already? what is your computer and what is the model of your router
  • 60 Answers
You might have changed the password for the wireless, this problem could be solved by pressing the reset button st the rear for 5 sec while the power on and the router will be reset at factory default settings, hope this will solve the problem
Posted on Sep 21, 2009
How can change user name and password in router D-Link?
Reading this question, I'm thinking that you want to change the SSID, this is the name that shows up when searching for wireless connection. First, you must find out what is your gateway, this is the main IP address. It usually is 192.168.0.1 or 192.168.1.1. Once you have that information, you need to log in the router, to log in, open a browser and type the gateway (Ex. http://192.168.0.1) A new window will pop up asking for a log in information. The most common default log in info are:
Username Password
admin admin
root 1234
admin password
Once you had successfully log in, take a look at what you have in front of you. There must be a tab name Wireless, click it. Look for SSID and change it to what you want to name it. Security should be in the same path, if not, save your work and log in again, but since you already change the SSID, you must search for the wireless connection again, and input the password, log in again.
If security is within wireless, then just head over to password and change it. You can also change the encryption type, I recommend WPA 2 personal. Once everything is all set up with the new SSID and the new password, click Save.
Search for the new SSID or router with your computer and input your new password once found by the computer./ Good luck.
May 31, 2015 | Computers & Internet
How to fix kindle fire 7 wi fi authentication failed
This is normally caused when the Kindle does not completely understand the authentication used or the Key used is invalid.
Step 1: Log into the Wireless router
Step 2: Verify the Key used, if the key stored in the Wireless is correct, reboot the Wireless Router
Step 3: When the Wireless Router is back online attempt to sign in again, if it fails log back into the Wireless Router
Step 4: Change the Wireless Encryption from WEP to WPA Personal and enter a passphrase
Step 5: Attempt to login to the wireless using the new passphrase
Apr 14, 2013 | Amazon Kindle Fire HD
I have wireless network Netgear / lost security key
Log into your router ( default log in details can be found by googling your make) if you have changed the log in details, you may need to reset the router to factory default ( again, google this for a how to)
Go to wireless settings and then security ( or the other way around depending on your model) and your key will be there
Jul 31, 2010 | NetGear WNR1000 Router
Hello I have a D-Link DR615 wireless issue. it automatic set to FREE wireless. why?I used to have password and also assigned a name for it. but now the Assigned name is NOT in the wireless network, instead...
It seems as though your router was reset to the default settings.
In this case, you need to connect to the "DLINK" network and reconfigure the router.
If you have the disk, you can use that to run the setup, or you can log onto the router itself and configure the settings.
To log onto the router, open a internet window and type in 192.168.0.1 in the address bar.
This will log you into the router.
Now simply select "wireless" and then wireles security and you should be able to set up the password again.
Thanks,
Pat
Mar 31, 2010 | D-Link DIR-625 (790069292637) Wireless...
SECURITY
log in to the router setup page.... you can type 192.168.2.1 in IE to open the setup page...on the left side you ll find an option called security below wireless heading...click on that and change the security mode to 64bit WEP....in the key1 you need to enter a 10-digit number (5pairs)as the security key for your wireless network...donot enter anything in any other boxes....click on apply changes....now close the IE...go to network connections and delete all preferred networks from your computer....now scan and connect again....it ll ask for a password...enter the security key and get connected....
Mar 23, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't get internet wireless
Log in to your router ( http://192.168.1.1 ) and go to the Wireless settings. Check your parameters, security modes, passwords. Using this info, try again to get to your wireless signal (your wireless on the laptop) should show up and let you log in. If the wireless function is not found, you need to install drivers for it onto the new hard drive. This ought to take care of the problem!
Nov 11, 2009 | Computers & Internet
Wireless adapter not found! Please insert the adapter now.
It wireless adapter could be faulty or the PCI slot in the computer is faulty.
Insert the D-Link into another PCI slot and also try installing the drivers again, the driver may be corrupted.
Try installing the D-Link in another computer, if it doesn't work then it is faulty and you need a replacement wireless adapter.
Aug 12, 2009 | D-Link AirPlus Xtreme G DWL G520 802.11g/b...
D610 won't acquire network address on wireless connect.
check firewall also check driver do you have a password on wireless router for wireless card
Mar 28, 2009 | Dell Latitude D610 Laptop Computer -...
Losing wireless connection after logging off
Log off? Not turn off?
Does the wireless work after you reboot?
If you log off but keep the computer powered it may be a power management issue.
Some network adapters have a setting to allow windows to turn them off to save power.
Go to the Device Manager, right click on the wireless adapter and select Properties.
Is there a Power Management tab? If so, click on it and remove the check mark from "Allow the computer to turn off this device to save power".
Sep 27, 2008 | Belkin (F5D5231-4) Router
Playstation network problem
Wired connection or wireless? If you are using wireless, try switching to wired temporarily and see if the PS3 stays connected.
May 18, 2008 | Sony Playstation 3 (PS3) Console
EnGenius EOC-3220 (EOC3220) Logo
232 people viewed this question
Top EnGenius Computers & Internet Experts
Michael Vincent Cruz
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
