Question about Kenmore Washing Machines
Have kenmore washer 8 years old will wash clothes and let water out but clothes not spinning. doesn't have belt on it
  • oldguy5 May 11, 2010
    Do you have the model number? Usually found on cabinet when you lift the lid. If it is pumping the water out but doesn't go into spin mode, have you tried lifting and closing the lid (or pulling out the control knob and pushing it back in)? If the washer will spin after lifting and closing lid it is the same problem that I had. It points to the "Neutral Drain" assembly. Some Kenmore / Whirlpool washers use what is called a Neutral Drain. Meaning that after agitating, the washer will drain the water before going into spin mode. The Neutral Drain assembly has a number of plastic parts and a very weak spring. If the spring breaks, the washer won't begin to spin. Stopping and starting the motor (lifting and lowering the lid) puts enough torque (twisting motion) on the drain assembly to connect the gears so that the washer will spin. If you are somewhat mechanically inclined you can fix it yourself by removing the cabinet, agitator, pump, motor and transmission. The neutral drain gears are in the transmission. A messy job but comparing the cost of the re-build kit (about $15.00) to a replacement transmission (about $170) it was worth the time and dirty hands to us.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Since it goes through it's cycle and pumps the water out, we can assume that the motor and timer are working. This points to two places.
There is a motor coupler (see the Sears sub category for motors and pumps in the Sears list) that provides power to the transmission from the motor. It's a fail safe device to protect both in case one of them jams.
Second, inside the transmission are a number of cams called the Neutral drain assembly that allow the machine to drain for a time and then begin the spin cycle.
On our machine, one of the cams that is supposed to have a spring didn't and the machine wouldn't spin unless frorced.
Here is a Whirlpool document with all of the components of their commercial grade washer, the consumer model is basically the same. Check the section on the Gear Case and look at item #26.
If you are relatively mechanically inclined, it isn't to hard to pull the transmission and get to the gears and cams. It's messy but can be done saving quite a bit of cash. (It cost us $15 for the assembly vs. $170 for a transmission.
Following is an excellent description from GURU JSROCK516 of how to remove the cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Posted on Sep 22, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Kenmore washer
You can check the belt. It's posible to be worn out.
All the best !
Oct 02, 2017 | Kenmore Washing Machines
Washer does not spin water out of clothes
Does the water all pump out? If it does and not spinning could be your belt slipping or two many clothes it it. If it doesn't spin out even a smaller load then it is more than likely the belt.
Nov 26, 2011 | Kenmore 24032\24036 Top Load Washer
Machine is not spinning
check the carbon brushes in the motor or the belt.if its not these then it may be a timer fault see if you have power to the motor
Jun 02, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
How difficult to replace belt for front load clothes washer Kenmore 8 years old? I'm an average handyman.
the belt is held by pulleys, there is an ajustment bolt loosen this (should be marked) to loosen the belt. some models have a frame bolt that must be removed to get the belt off. this repair should be fairly easy to do.
Apr 21, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Front loader washer doesn't spin clothes as dry as before
The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
