Question about Garden
Bogs out when I rev up the saw it sounds like its bogging out then dies. even when not cutting
    Guru:
  • 597 Answers
First check the air cleaner. Clean or replace it. You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw usually on the left or right side of the carburetor on the outside of the housing. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn. After adjusting the mixture it might be necessary to readjust the idle speed.
Posted on Sep 13, 2009
How to make adjustments on a chainsaw it will run fine for a while then when you get to cutting good it wont run when you mash trigger
it could be a number of things. if the saw runs and revs up fine without load then bogs under load then change your clutch springs. if it bogs out with no load then its a fuel system problem
Sep 30, 2014 | Husqvarna Garden
Does cut off saw need carb adj. it bogs down while cutting
It sounds like you are cutting something heavier than your saw can handle. I would check the manual and the limitations of your saw. If it is getting bogged down when sawing very small, thin things then the chain might need to be replaced. Don't keep using it until you have replaced the chain if that is the case.
Elisa Jed ' http://www.ascotconcretecutting.com.au/services.html
May 15, 2014 | Saws
Bogs down while cutting does carb need adj.
Every saw is going to bog down some when cutting. What condition is the blade? I would need more information on what kind of saw it is in order to try and help. Is this gas powered? Wet saw? Wood, concert or steel?
May 15, 2014 | Saws
Have trouble starting homelite textron chian saw carb setting
First is the gas mix right? 2 ids the air filter clean? 3. have you replaced the tank fuel filter to make sure it's getting gas? 4. is the plastic line cracked? 5. adjust both carb screws all the way down gently then reverse the screws counter clockwise 2 and 1/2 turns, this should allow it to start and run, once it has started let it warm up and adjust the idle for it to run smooth without dying. Once its running rev it up to make sure it does not have any dead spots in it then try a test cut, if it bogs down adjust the gas screw to in rich it just a little and try cutting again if it does not bog down you should be set. there are other things that can cause it to run poorly like a bad carb gasket or loose screws on the carburetor. If you need more help post here and I will give you some other things to look at.
Nov 07, 2009 | Homelite Garden
Runs great for 30 sec. to 1 min. then dies slowly
Is it your chain saw Husqvarna 40?
Try carb adjustments H-3/4 turn ,L-2 turns and T a little higher
I presume that compression and ignition sistem is adequate for the engine to run.Good luck
mihai
Apr 04, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Garden Logo
330 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
