My computer shuts down after 3 secs
Hi I have 2 problems first my monitor dowsnt turn on when i turn my computer on or my computer shuts down after 3-4 secs
ASROCK K7VM2 motherboard (this one wont work with my monitor)
Amd duron 1400
Seagate 20 Gb
512 Mb ram
ASROCK K7S41GX motherboard (shuts down after 10 secs or less )
AMD Athlon xp 2500+
seagate 20 gb
512 mb ram
can someone help me with my problems
  • Anonymous Nov 05, 2008
    my pc turns off in 2 secs.opened my pc to watch whats going on. the fans in powersupply and on cooler will turn for 2 secs after pushing front panel button and quit. it wont power on again unless i unplug the power cord before pushing the power button. but then again will stay on for 2 secs only. its a sony vaio pcv-rx580
  • 1,226 Answers
Try to separate the power cord of your monitor from your system or maybe if your using UPS(uninterrupted power supply) directly plug the UPS to the wall outlet. either you can use pretty voltage regulator to the regulate the AC power.
if not solve the problem try to examine the your system power supply.
Posted on Dec 11, 2007
How to fi a phillips 20fp shuts off in 2 scs.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 29, 2014 | Philips Phillips 20" Color Monitors Model...
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Hi i have a problem about my lcd viewsonic va702, when starting my computer i can see the image for 1 sec then it turn black ...lcd light is ok and computer too already tried with other lcd all works fine...
this works for Dell monitors with a similar problem: shut down, turn off monitor and pc, turn off at wall socket, and remove power plugs from wall socket. wait about 30 seconds. plug back in, turn on, and all should be well? I have used this 3 times on a Dell PC with a Viewsonic monitor.
Dec 23, 2010 | ViewSonic VA702b 17" LCD Monitor
Hi my computers screen is blinking it goes down for 2 secs and com back again from boot to startup but monitor is working fine on other computer
Make sure the plug from the monitor to computer is plugged in securely. Then, if the problem continues, replace it. It's on it's way out.
May 20, 2010 | Envision EN-985e Monitor
My acer al1511 monitor started shutting down after 2 or 3 minutes, the green power led turns orange(like no signal). if i turn the monitor power button off and back on the monitor works for 30 sec to 1...
Here are the service manual (not usre which model you have, downloads are limit to two per day):
You need to do some voltage checking make sure you do have 5 and 12v. The caps the secondary DC side should all be replaced at the same time, it may look OK but they can have high ESR, and they also should be low ESR type such as FM or FC series by PANASONIC. You can send me pictures if you want more help,
Apr 23, 2010 | Acer AL1511 15" LCD Monitor
Monitor just turns itself off after 2 sec.
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 16, 2010 | HP w1907 LCD Monitor
Monitor turns itself off
hi, you must have enabled power saving options. Thats why your monitor shut down. you can disable, just do the same:
1.Right click on desktop
2.Select properties.
3.Select "ScreenSaver".
4.Select "Power" under Monitor power option.
5.There select "never" from Turn off monitor (drop down menu).
Now your monitor will not turn off automatically.
Sep 19, 2009 | Dell Inspiron 531s Desktop Computer
I have same problem
Replace the following capacitors:
3 pcs - 220 microF - 25v
2 pcs - 1000 microF - 25v
1 pc - 2200 microF - 25v
Resolder the 2 transformer legs for the inverter.
Triangle Tech Whiz.
Jul 23, 2009 | Acer AL2216W LCD Monitor
Hmm... is still not working
Start your computer and tap the F8 key as soon as the computer begins to power-up. Keep tapping until you come to the Safe Mode screen. When the screen alerts you to the fact that you have chosen Safe Mode, click OK.
When you get to the desktop go to the control panel and launch System Properties. Go to Hardware and Device manager. Click the arrow next to the Display Adapter. Point at the adapter, right click and chooser Properties. Click the Driver Tab. Roll back the video driver to previous driver.
If indeed you have installed a new driver that is not compatible with your video card, then rolling it back to the original may very well take care of this problem.
Aug 14, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
Look up the BenQ website.
These monitors have a 3 year warranty in most cases.
Failing that cantact BenQ directly with the phone numbers on that same site.
Apr 07, 2008 | BenQ T705 17" LCD Monitor
Computers & Internet Logo
372 people viewed this question
David Payne
David Payne
