I have a toshiba estudio 4511 it sounds as if it is powered up all the way but the screen stops on a grainy screen with a picture of the copier and the screen itself. no buttons will work it just sits there and does nothing. it is not connected to a computer, we just use it strictly for a copier nothing else. I can not use the machine at all
  • 149 Answers
The operating program is stored on a hard drive in the copier. If the hard drive has a problem, the operating system does not start, just like a computer being stuck at start up. To get the firmware for this copier, you will probably have to call for service.
Posted on Sep 12, 2009
Studio has an error message to close offset tray cover estudio 450 copier
Need check cover open or not. if open closed covers properly
Aug 13, 2015 | Toshiba e-STUDIO 4511 Printer
Error f090
H
I have managed to find a description of this error here:
Error Codes Toshiba Studio 4511 Code F090
which says:
Description:- SRAM abnormality on the SYS board
Unfortunately the page doesn't give a remedy for this error as it normally does, but you can download a pdf format service manual from this site by clicking on the link near the top of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Toshiba Estudio 4511 Color Printer,...
My Toshiba estudio 4511 says call service
Your CYAN is one of 3 colors the "Smart guys" came up with to make 252 some colors. Between Cyan Magenta Yellow and the ever so present Black you can make all your colors. Obviously you don't need the three C,M,Y to make a black and white copy. So the issue remains that a low or empty Cyan (pronounced S-eye-ann)
A couple differant issues I've run into since the creation of color copies near 2003 is A pull tab on the toner isn't pulled off before inserting the tube. Another is for several possible reasons the toner just isn't getting down into the developer mixing auger. There is also, upon occasion a situation that the motor that turns the toner auger inside the new toner cartridge doesn't turn enough/properly/ or at all. These days that will almost always throw a code in the display window. My 23years of Toshiba tells me try your C cartridge, play with it a bit and make sure its in right, with tab pulled. another tool is monitoring how long it tries to and the Cyan, does it attempt to restore it' levels for about 90 seconds or is it immediately tell you there's a cyan issue? Can you hear the motor and toner bottle turning? It should tell you "adding Cyan Toner" or even "Check Cyan Cartridge" worst case scenario you call Toshiba business Solutions and they vacuum it all out and do some adjustments......could be a good thing With Toshiba you get a lot of bang for your buck, meaning: a service call is good every once in a while. Your 4511 is a work horse you won't regret $pending for service. ~~~~~> SC
Sep 22, 2014 | Toshiba Estudio 4511 Color Printer,...
My printer says call service
When you turn it on, it does a self test. Something has showed up as not working and it is asking you to call for help.
there's information in your manual to get the error code and you can decide if you want to get it fixed.
C020 ON ESTUDIO 4511
There's a paper jam while the paper is trying to exit the printer. The definition of the error is saying that the leading edge of the paper has reached the exit sensor, but the other end of the paper hasn't yet. Because it's jammed...
It could just be a regular paper jam that needs to be cleared, or it could be a faulty exit sensor or a faulty registration roller, or registration sensor. I'd try clearing the jam thoroughly, and then try printing again. If it's a recurring error then you may need to call someone to replace a faulty part...
Jan 27, 2011 | Toshiba e-STUDIO 4511 Printer
Toshiba 3511/4511 suddenly stopped faxing
Try use the monitor button for faxing, check whether there is tone or not.
Jul 08, 2010 | Toshiba E-Studio 3511 Color Copier
Idon't found the driver of toshiba 4511 for windows 7 what can i do?
I can't say for sure on the 4511 but most of the older copiers and printers are working with Windows7 using the Windows Vista driver. Have you checked Toshiba's site? The 4511 is getting a little dated so it could be that they will not make a driver for it which would be bad. I would check the Toshiba site and if nothing else try the Vista driver.
Good Luck and Thank You for using Fixya
May 09, 2010 | Toshiba e-STUDIO 4511 Printer
I want reset my estudio 163
Press *+1+3 and power on the machine.
Nov 29, 2008 | Toshiba e-Studio163 Copier
27 people viewed this question
jasbo
jasbo
