Question about Craftsman Garden
I have a Craftsman Blower/Vac model 358.794770 that won't start. I'm not getting any spark from the plug when I pull the rope. I've replaced the plug, ignition module and the wiring harness but it still won't spark. I also disconnected and bypassed the shutoff switch but it still won't start. What else would prevent this unit from starting?
  • 124 Answers
Most likely low compression caused by stuck piston rings or a scored piston and cylinder. This unit was made by Poulan and they have had an epidemic of this problem. The solution is to tear the unit down and put in new piston rings. Before you install the new rings you need to get a sheet of glass and some 600 grit wet dry sand paper. Sand each ring down about .002 to .003 and reinstall. This should solve your problem as long as you have good fire and the piston and cylinder is not scored.
Posted on Sep 14, 2009
50 PSI compression on mine. Should be 100-110. I thought the 50 hrs rating was for compliance to emissions; a friend repairs garden tractors, blowers, weed whackers, ... informed me this is generally the life expectancy. That is just about what I got out of it, three seasons between leaf blowing and grass cutting clean up I got a little more than 50 hrs :( He recommended Echo.
Posted on Aug 15, 2010
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Tecumseh pull start engine on Craftsman Lawn Vac will not pull. Feels like engine is locked up.
the engine is probably not locked ! remove the plug wire, tip up and see if the blade turns. if so, try the rope again. if it wont pull, take top off mower off to investigate the pull rope problem. good-day !
Nov 07, 2011 | Garden
I can't get my Poulon leaf blower to start
So far everything looks good. You're getting fuel, and you're getting spark. Only problem, is you've gotten too much fuel in it, and need to get rid of some before you can proceed. Take that spark plug out, and pull the starting rope hard several times. This will force the largest amounts of fuel out. Now's the part where you'll have to trust me. Use a match or a lighter to "flash" the cylinder. Make sure you don't have excess fuel spilled over the blower, but hold that match or lighter right up to the spark plug hole, and it'll "puff" at you. Please don't look into the hole while you're doing this. Flash the cylinder, and then pull the rope again, and flash it again. Next, make sure the spark plug is dry then put it back in. Set your choke to full choke, and pull until it hits once. Then put the choke on half, and it should start within 3 pulls.
Mar 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
How to check for spark on leaf blower ?
hi
ground the sparkplug at the cilinder and pull the rope.see if there is a spark.if not try changing the sparkplug
Sep 23, 2009 | Craftsman 4 Cycle Blower/Vac
Ihave a sears 2 cycle blower,vac and is not getting spark, is there anyway to check the igniter module--bill
remove the spark plug, plug it back into the plug wire place a screwdriver on the spark plug and the cylinder and pull the starter rope - if there is spark, you will see it on the plug [or you will feel it!]. if you have spark, put the plug back in and try to wiggle it side to side, if it rocks freeley, the cylinder bolts have come loose [a very common problem with these units]. the fix is pretty involved and not fun
Apr 04, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman 2cyl leaf blower wii not start
it sounds like vapor lock, trying giving it a couple pulls with the spark plug taken out
Nov 13, 2008 | Craftsman 4 Cycle Blower/Vac
Craftman 205 mpg 2 cycle gas blower 40:1 raito will not start.
Similar experience with the same blower. I cleaned the carb checked for spark but I still can't get it to start
Garden Logo
844 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
