Question about Dell Office Equipment & Supplies
Printer make noise like printing but will not print seems like out of ink but put fresh cartridges in. will not print
    President:
  • 1,653 Answers
Run at least one or maybe two cleaning cycles then run the test printout to see if it is OK.
Posted on Sep 12, 2009
Clicking noise when printing
Had similar problem. Putting my hands on the front surface of the printer, the click seemed to be felt strongest in front of the pink ink cartridge. I took the cartridge out, looked at the back of it, where there's a little black wheel, and tried turning it. That wheel was stuck (whereas the other colors & the black would turn). Tried printing with the pink cartridge out and no more clicking noise. I guess I'll just replace my pink cartridge. Maybe see if there's a similar problem with one of your cartridges?
May 13, 2010 | Samsung CLP 300 Laser Printer
Ink clog between magenta cartridge and print head.
print head may be burned out try cleaning it then tap the cartridge and try a test page to see if it prints, if it still does not work try a new cartridge if that does not work then the print head is burned out, it may be under warranty you can go to www.hp.com and input your model and follow the trouble shooting guide and if you can't fix it you can register for free live chat help with the problem and it may be under warranty, many printers are having problems with this color cartridge drying up and causing problems not only hp but other brands as well. I suspect the pigment drys up but am not sure about it.
Feb 11, 2010 | HP OfficeJet Pro K8600 Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Done all the things you advise to clear the print heads, it seems to relate to the large back cartridge, ink flow seem ok, sponge pad at base of cartridge moist with ink. All other inks fine on test print....
Yes, the print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0075.
Nov 13, 2009 | Canon MP610 Photo All-In-One Printer
Printer won't print, makes clicking noise, on/off light flashing
This method should put you on a fresh footing.
1. Go to start button when programs appears see if you can find your printer in the list, see if it has an uninstall program.
2. If not: Go to start click on printers and faxes.
3. Delete the printer giving you a tough time.
4. Reinstall using your installation CD.
That should work.
Victor
Dec 19, 2008 | HP Photosmart 2410 All-In-One InkJet...
Ink cartridge (not) installed properly
For the Canon iP1800 printer are you sure you're using the 30 for black and 31 for color?
And make sure they "click" when installed. That should confirm that they're nice and tight in their ink compartments.
Besides that, maybe reinstalling the printer drivers could do something?
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Color not printing
If you are making copies or sending/receiving faxes Press Black Start or Color Start. Make sure your ink cartridges are fresh. Cartridges remain fresh for up to two years if kept in their original packaging, after that the ink may become clogged. Cartridge expiration dates are printed on the package.
Sep 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Red not printing
The only thing I can suggest, short of replacing it, is to shake the cartridge, hard. That sometimes will clear interior clogging. If you see fresh ink on the bottom, you're on your way. Put the cartridge back in and run another cleaning.
Mar 23, 2008 | Brother MFC-5840CN All-In-One InkJet...
Failure to print in Black ink
I see this alot in epsons. What is happening is probably this:
The carriage that you put your cartridges in is called a printhead.
connected to the printhead is a long tube for pumping wasted ink down to a waste pad that soaks up the ink. Over time the ink builds and clogs the hose, which backs up and clogs the print head. It is usually more common to happen at the install of a fresh cartridge and it does that first charge. To make a long story short, unless you can hot chemicals to run through it, it is dying.
Jan 07, 2008 | Canon S 750 InkJet Printer
44 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
