I have an rca tv with the dvd player attached and I am unable to turn it on or change the cannels because the front panel is locked and my children have lost the remote. Is there anyway to unlock the front panel without the remote?
  • 525 Answers
No,you can't do that without remote . try to find a universal remote .
Posted on Sep 12, 2009
How do I turn off pscan on a rca dro2oon DVD player
IMPORTANT:
If you don't have a Progressive Scan TV or you don't have the DVD player connected to the correct Input Jacks, and you activate Progressive Scan in the DVD player you won't see a picture! Don't panic-try the following:
First, press the PREV/VIDEO button on the front of the DVD player (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If that doesn't work, press and hold PREV/VIDEO button on the front of the DVD player for 3 seconds. Now, press the PREV/VIDEO button again (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If you still don't see a picture on your TV screen, make sure the yellow cable (provided) that is attached to white and red cable (called audio/video cables) is connected to the DVD player's PREV/VIDEO jack and the TV's Video Input jack. Change your TV channel to your TV's Video Input
channel that activates the TV's VIdeo Input jack where you have connected the yellow cable (page 9 of your manual has more information).This PREV/VIDEO jack on the DVD player always outputs interlace video, so you should see a picture on the TV screen.
As a last resort, you can reset the DVD player to the factory default settings:
Press and hold the STOP button on the remote control and the NEXT button on the front of the player at the same time - wait at least 5 seconds before you release both buttons
Sep 25, 2016 | RCA Televison & Video
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
My rca tv reads function disabled when I push the menu button on the front of my tv. how can I enable it?
easy. some rca tv's have a disable function for the buttons on front of tv. keeps little children from changing channels and going into menu. you need a remote to access the menu. then go into parental child lock function in menu. hope you are not the child and your parents locked the front buttons. hehe
Nov 08, 2009 | RCA Televison & Video
Durabrand DCF2003
try opening it up and clean the remote with alcohol and soft cloth.let it dry.while drying, check the rubber buttons for breakage.then assemble.be sure your batteries are ok.
May 28, 2009 | Durabrand DWT1905 TV
Lock code how to un lock it
If you have a RCA Truflat TV/DVD combo try code 8888 to unlock parental control settings.
Apr 18, 2009 | RCA 20F610TD TruFlat TV/DVD
I am unable to get the dvd to play
just turn on both the dvd player and your tv set...then set your tv program into AV mode or INPUT mode,and connect the RCA cables from the output of the dvd player into the input socket of the tv system...be sure that the colors or the RCA wires must correspond to the two sockets namely the the OUTPUT adn the INPUT..you can now activate your dvd player!!!
Oct 27, 2008 | Polaroid 3211TLXB 32 in. LCD Television
I acccidently put my RCA 36" TV into FTP Lock mode and now it won't turn on. What to do?
Get your remote and turn the TV on and turn FTP lock off.  FTP is a program used so children can't use the TV panel so it makes the television useless. Pretty simple solution.
Jul 04, 2008 | RCA Televison & Video
Recieving "Locked" display message but don't know how to clear it. No reset switch or panel lock button
I have the manual and it is called "child lock" go figure it stumps us adults. Anyway...holding the power button down for approx. 8 seconds can toggle this feature on / off
Jun 18, 2008 | Apex Digital ADV3800 DVD Player/VCR
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
Durabrand DCF2003
All you need is to press the input select button on the remote to change between the tv and the video inputs.
May 23, 2007 | Durabrand DWT1905 TV
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
