Question about Poulan Pro Chain Saw 46cc 20"
Wont run hard start, run for five min or less then wont start
    Guru:
  • 597 Answers
Many chainsaws have the fuel tank mounted very close to the engine cylinder. In the process of filling the tank over and over a lot of mixed gas is spilled and some of it runs down on the cylinder head. Being mixed gas and having oil in it, it leaves an oily residue. This oil will seem to collect a massive amount of sawdust over time. The sawdust coating the cylinder causes it not to cool down really well and the increased heat can cause the fuel in the tank to boil if it's bad enough. If the vent in the fuel cap is plugged and the gas in the tank gets hot it tends to pressurize the gas tank. This can cause the saw to flood out or load up.
Change the gas cap or clean out the vent filter. If you can get to the cylinder clean all excess oily sawdust from the cooling fins.
If you get the saw running your probably should readjust the mixture settings.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Posted on Sep 13, 2009
Why is my nordictrack T6.3 making loud humming sound all of the sudden?
You don't oil belts as oil will eat away at the rubber. Start with running the machine and checking for lumps of wax build up at rollers (most common issue) if this is not it try oiling roller bearings. But call manufacturer first to see if your warranty is still good because as soon as you touch it it will void warranty.
Jul 18, 2014 | Nordic Track NordicTrack T6.3 Treadmill
Wheh i try to start it it sputter and barely start but it chugs and dies i checked fuel line it is getting gas can you help
Check fuel pressure,
most likely you need to replace fuel pump
not that hard and only takes about 30 min
pressure needs to be around 65 lbs
5 lbs less and it wont run
Jul 09, 2014 | 2001 Chevrolet Silverado 1500
2003 Grand Cherokee diesel - intermittent starting issues when the front of the jeep is elevated. Turns over but often wont fire for four or five attempts, occasionally will not fire at all the starts...
As when front elevated, possible small leak on fuel pipe, check connections, air getting in fuel runs back to tank, so when starting, has to pull fuel back up before starting
Mar 16, 2013 | Cars & Trucks
I have a 2004 audi a6 3.0. i put a new timeing belt on it and now evey time i try to strat it just wont **** on
you will need a computer rest to get it to start on your code readers they wont rest mem codes only the dealers can rest those....bmw is the same way i did the same thing . dealer zapped it in five min car runs great now
Sep 12, 2012 | 2004 Audi A6 3.0
Starts well,runs wellfor five mins but then cuts
My first guess would be the fuel filter. It is probably almost completely plugged.
Oct 23, 2009 | 1991 Volkswagen Passat
My kenmore gas dryer turns on and lights runs about five mins. hot and then starts blowing cold air and ignitor keeps glowing on and off but wont light flame
see if the thermal bulb is located in the path of the flame, and if it is you will have to change the gas thermal sensing bulb.
Aug 14, 2009 | Kenmore Dryers
My PS3 freezes up shortly after start of game, won't run movies
I believe you may have little or no memory left...
you can upgrade it with a 500 Gb HDD from SATA (2.5' 8or 16" MB Cache make sure it is 5400 RPM ) You can buy it at best buy..
I replaced mine... and it works great now.. when you replace it you can download the software into your external hard drive and transport it back into your ps3..and itll instantly upgrade it for you
Jul 02, 2009 | Sony Playstation 3 (PS3) Console
Poulan Pro Chain Saw 46cc 20" Logo
222 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
