Question about Hitachi 53UWX10B 53" Rear Projection Television
Cannot find the adjustments for convergence behind the control panel a described. not able to bring up the crosshairs to ajust convergence as described in many replys. help 53uwx10ba model
  • Hitachi Master
  • 3,459 Answers
Your tv may have a small button hidden on the board. You will need to look behind the speaker panel at the circuit board. Its a small blue button located on the convergence board.
Posted on Sep 19, 2009
Is there a code number that needs to be entered to bring the convergence pattern or menu on screen.
From a user standpoint you would follow these steps to bring up your Convergence menu:
1) Press your MENU button.
2) Press the Right Cursor Button to enter the Picture menu.
3) Press the Down Cursor Button until you highlight the MANUAL CONVERGENCE choice on the menu.
4) You will then see the following choices on the right hand side of the menu: Convergence Red, Convergence Blue, Multipoint Red, Multi Blue, Save Multipoint.
5) Once you choose either the Red or Blue choices you will get a crosshair in the middle of your screen. You will then use either your Up, Down, Left, or Right Cursor buttons to get the two images to line up correctly. If you still have multi images on your screen in either Red or Blue you would then have to adjust the Multipoint choice for that color.
May 14, 2011 | Philips 51PP9100D 51 in. Television
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
    If the following doesn't work the tubes could be at the end of life:
    Adjusting convergence:
    Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
    To adjust the convergence of the picture tubes:
    1. Press the 'MENU/SELECT' button on the remote.
    2. Press CURSOR RIGHT to enter the PICTURE menu.
    3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
    4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
    5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
    6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
    7. Press the 'EXIT' button to exit the menu.
    If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
    To Adjust multipoint convergence:
    2. Use CURSOR RIGHT to enter the PICTURE menu.
    3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
    4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
    5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
    6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
    7. Press the 'EXIT' button to enter ADJUST mode.
    8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
    9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
    10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
    11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
    12. Press CURSOR RIGHT to save the multipoint settings.
    13. Press the 'EXIT' button to exit the menu.
    Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
    How do you set convergence
    What is your Make and Model number?
    I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
    http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
    The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
    Please rate my help++++Thanks for using FIXYA
    Nov 24, 2009 | Philips 46PP9302 46" Rear Projection...
    Blue Convergence
    Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
    http://electronix.com/
    Jan 14, 2008 | Toshiba TN55X81 55" Rear Projection...
    Convergence problem
    As long as you still have your On Screen Display coming up with channel information, it is likely your problem lies in the convergence IC's and possibly a couple of fuses that supply power to the IC's as well. This is assuming that no one has gotten to the inside convergence board and messed with those settings.
    Jan 24, 2007 | Sony KP-61S65 61" Rear Projection...
    Open Questions:
    See all Hitachi 53UWX10B 53" Rear Projection Television Questions
    Hitachi 53UWX10B 53" Rear Projection Television Logo
    171 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
