Question about Samsung ECX 130 QD Film Camera
Samsung ECX 130 Film Camera battery
Could someone please tell me what kind of battery does this camera take?
It is not AA or AAA - not the regular kind.
It's my mother-in-law's camera and she had lost of the battery and manual.
Thanks very much
  • 16 Answers
SOURCE: Samsung Digimax 430 - Battery Problem
Are you using specialised batteries? Kodak, among other brands, have AA batteries designed for digital camera use - the high intensity usage flattens normal batteries very quickly. They aren't much more expensive, but last a lot longer.
Posted on Sep 12, 2005
mattozan
  • 555 Answers
SOURCE: Samsung Impax 210i Camera
When this happened in my camera, it meant that the film winder gear was stripped. How old is this camera?
Posted on Apr 11, 2008
SOURCE: samsung s1050
In the menu, there's an option for "batteries"- make sure that's set to Ni-Mh
Posted on Jul 13, 2008
SOURCE: Samsung F700V shortcut display problems
I have the same problem with my samsung SGH-F700v. When it's cloused the touch screen is not working but when it's open it works. The problem is in the cable the connects the keyboard with the screen, so you need to change it. I haven't figured out why yet, so if anyone does just reply.
Posted on Sep 18, 2008
  • 383 Answers
SOURCE: my samsung digimax s500 camera still says card locked every time i go to take a pic.Someone kindly sugested holding the rest button, but i
THe SD card inside has a lever to its left Side .... Move it upwards ..... That is the lock on the Memory Card ...
Posted on Oct 16, 2008
What kind of charger does this Kodak Dashboard CW330 take?
The original battery pack is nothing but 2 AA batteries held together with a plastic holder, you can use regular AA rechargeable batteries and save some money. I had a similar camera with the original battery pack held together with some plastic holder, I simply substituted that battery pack with 2 regular rechargeable common batteries and camera works the same.
Mar 03, 2015 | Kodak Cameras
I am wondering if anyone could help me please, i have bought some 2600 mAh AAA batteries for my video camera. I was wondering what kind of battery charger i would need to get to recharge these batteri
Any charger that will charge AAA batteries should do the trick. I have several 2600 mAh batteries, and use chargers from RayOVac, Nuon, and others without any problem.
Jan 30, 2015 | Cameras
HOW TO LAD BATTERIES
Are these just regular "AA" or "AAA" type batteries? If so, the negative side goes to the spring.
Apr 12, 2013 | Cameras
Can i put AA batteries in my finepix F60 camera instead of using the lithium ion battery
I doubt you could fit three AAA batteries inside the camera. Chargers aren't that expensive if you know where to look. Take a look here for some examples.
Oct 26, 2012 | Fuji FinePix F60fd Digital Camera
I just got a ViviCam T027, what kind of batteries do i need??
for some reason they take either AA OR AAA batteries. remove the batteries and it will say on the side what type. AAA batteries or small. AA are the larger "penlight" batteries. i would suggest/recommend that you purchase a set of rechargable batteries for the camera. 600ma minimum but higher ma would be best. most dept stores such as walmart etc will have charger + battery combination packs you can buy. as a side note buying dollar store batterys etc will be a waste of money as i've tried it. you might get one or two pictures from a set of batteries. your other choice is a good set of alkaline batteries. but rechargable batteries are your best option.
robert
Dec 23, 2010 | Vivitar ViviCam 3915 Digital Camera
What kind of AA batteries do i need to use for my Nikkon N80 with converter box. Can I use the regular alkaline batteries or do I have to use Iithium batteries.?
If you are referencing the added grip, MB-16, you may use rechargeable AA batteries, or other regular AA batteries. My preference is rechargeable.
Sep 08, 2010 | Nikon F80 35mm Film Camera
Can't get my camera to advance the film. I put new batteries in but still nothing Is there a particular type of battery I should be using for it??
Hi Susanabbott2, As long as you are using AAA batteries, unless you have the holder for AA batteries it should advance the film. Things to look at: With the batteries in camera turned on do you see the red display in the view finder, if not there is an electrical issue, if you do see it do the following. Open the camera back make sure the leader is pulled to the red marker on the lower right. On the camera back door is there the chrome springy thingy with the little roller? If not then as you close the camera back there is nothing to place tension on the film so that the sprockets can grab the film.
May 06, 2010 | Nikon N2000 35mm SLR Camera
WHERE ARE THE BATTERIES LOCATED IN THE SAMSUNG ECX1 PANORAMA film camera
take a pin and stick it in the whole and it takes 2 3 volt batteries
Apr 07, 2010 | Samsung ECX 1 35mm Point and Shoot Camera
Hi, I have an Olympus fe130 and it keeps saying the batteries are dead when they are brand new. Any ideas? Thanks, Erica
The camera uses very common "AA" batteries, but infortunately AA batteries come in various "stengths", and the FE130 requires a very high strength AA battery- you may have a battery, that will fit in the camera, but just doesn't have the power for your camera, Also, the batteries may be "new" to you (you bought them recently), but they may have been on the store shelf too long (most "throw away batteries have Expiration dates on the package and sometimes on the bateries themselves- if they are still "in date"- have someone check them with a battery tester or voltmeter- if you don't have either of those- see if you have some other device ( a small flashlight) they might fit in to check- occassionally batteries go bad. There is also the possibility is that you purchased AA batteries that are rechargable, like NiCad, that don't have to be thrown away), but they need charging before they can be used, and regularly to keep their charge. If you tell us what the battery label says and any date info it might have we can probably know more.
Sep 12, 2009 | Olympus FE-130 Digital Camera
Replacement battery
takes 2 AA batteries, if this is a vivitar camera, ordinary one not lithium
hope this helps
Aug 08, 2008 | Vivitar 450PZ 35mm Point and Shoot Camera
Photography Logo
43 people viewed this question
Top Samsung Photography Experts
pontelemon
pontelemon
Tom Chichester
Marvin
Marvin
Are you a Samsung Photography Expert? Answer questions, earn points and help others
