Question about Viking 30" Dual-Fuel Range, VDSC3054B Dual Fuel Range
Have a Viking range, gas top, electric oven, neither work.
Have a Viking range, gas top, electric oven. Ignitors on top don't work, or even make click noises. Oven also does not work. Problems started at same time. There is electricity to unit, oven light works.
  • 22 Answers
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Posted on Sep 12, 2009
New ignitors in Viking range oven do not heat up
You will need to measure for 110 VAC at the control switch located on the thermostat. Pleazer Appliance...
Apr 15, 2014 | Viking Kitchen Ranges
Calibrate oven
i couldn't find your model on the sears site,every viking stove i've worked on had two ignitors,if one of the ignitors isn't working correctly could cause heat changes in the oven.if you pull out the racks,then remove the side rack holders,lift up the floor so you can see the ignitors,start the oven,as soon as the ignitors start to glow time them,if they don't ignite the flame within 40 seconds the ignitor is bad.if this is the problem you don't have to calibrate the oven.also if the ignitor or both are bad check the burner tube to see if there's a hole in it.my friend john had trouble with his oven,i went over,had to change out both ignitors and both burner tubes,the ignitors weren't working correctly and burnt a hole through the tube.so check the ignitors first,if you want to calibrate it look at your manual and it should tell you how to do it,or oull off the thermostat knob,look on the back there might be screws there to calibrate it or if there's a hole in the shaft in the shaft that you pulled the knob off of you might need a small screw driver to stick in there,turn it slowly and not to much to the right to increase the temp.hope this helps but start with the ignitors,they are usually the problem.
Dec 18, 2011 | Viking 30" Dual-Fuel Range, VDSC3054B...
I have a gas Viking range. The oven burner ignitors light up and ignite the gas burners but quickly shut off - then go on again and off again- intermittently but frequently. This does not permit the...
Here is a test you can use to check the ignitors, Ignitor test. I also would like to you turn the thermostat knob slowly from the off position, When do you hear the click in the knob? You should hear it before the warm or lowest numbered setting on the knob. If you don't, replace the thermostat as it has failed. Need full model number to get you part.
Good Luck
Stay dry out there!!
Aug 28, 2011 | Microwave Ovens
One of the oven ignitors does not work
Most likely replacing the ignitor will fix it. I usually replace Viking ignitors with Maytag ones, part number 12400035 (you'll need splice wires and use included wire nuts to connect those, though). Those have a little shorter base, which does not affect anything. Replace both bake ignitors if you can, otherwise, one of the burners will ignite slower and shut off faster, resulting in uneven bake.
Jul 17, 2010 | Viking VGSC306-4B Gas Kitchen Range
Viking oven not heating past 150 degrees
My viking oven had same issue - I needed to replace the ceramic ignitors (if ignitors fail to heat up properly the gas valve remains partially closed). Apparently they are intended to be replaced every 3-5 years. Also inspect and clean the oven burners - mine had corroded somewhat and prevented the flame from 'moving' to the opposite side - ie only half the burner was lighting. If you are handy the ignitors are very easy to replace - one screw, two wires each.
Jan 02, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
Burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Lp gas double oven gas bake valve
i believe your problem has been the ignitors the whole time . make sure you are getting the viking factory parts for the ignitors its a part #PB040001 it should come in a small factory box with the part # on the box
Sep 27, 2008 | Viking VGIC485-6G Gas Kitchen Range
Viking oven
We had a hurricane come through and power was out at our house for 2 weeks. The top burners worked but the oven would not. Our outside gas grill worked perfectly also using the utility provided natural gas. We were told by Viking that the oven is designed to work only when there is electric power. This is a safety feature, according to Viking.
Sep 22, 2008 | Viking VGSC306-4B Gas Kitchen Range
Viking 30"  Dual-Fuel Range, VDSC3054B Dual Fuel  Range Logo
649 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
