Question about Olevia LT27HVX 27 in. LCD Television
Olevia turns itself off!
My Olevia also turns itself off, however mine only stays on about 5 minutes. Once it turns itself off, it takes about 2 minutes for the blue light to run back on, then I can turn it on again- but it shuts itself off again in another 5 or so minutes.
Customer service had no suggestions other than not using a power strip, unplugging it for 2 hours, and hitting the reset btton. None of those suggestions helped!! Has anyone been able to solve this problem!?
SOURCE: Olevia LT42HVi turns itself off after 2-3 hours of
I have a different problem. Are are interested selling parts?
Posted on Jun 16, 2009
  • 541 Answers
SOURCE: Olevia 747i won't turn on, no blue led light? Help!
I would start with the power supply. Possibly a fuse. 9 times out of ten though if a fuse goes, something inside the set is causing the fuse to blow.
Posted on Oct 13, 2009
toolkits
  • 1099 Answers
SOURCE: television will not come on, blue light stays lit
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck....
Posted on Jul 30, 2010
  • 17 Answers
SOURCE: olevia 242fhd-t11 Has no power. Will not turn on
I am guessing that since you are checking other outlets that you are getting no STB light or anything. So you will want to start by looking at the SMPS on the unit and see if the 5A 250V fuse is blown or not. If it is blown then you can try replacing it but I would bet that it will just blow again. So you need to replace the SMPS
Posted on Sep 09, 2010
TV #1
  • 129 Answers
SOURCE: I have an Olevia 42"
The issue you are having is your power supply
Thank you
www.orlandolcd.com
Posted on Dec 07, 2010
My 27" Olevia LT27HVX turns on and then seconds later it just keeps turning off and on
sounds like your power switch is broken. Take the battery out of the remote and see if it still turns on and off. If not its your remote. If it keeps doing that, you may have to get the power button replaced.
Dec 18, 2012 | Olevia LT27HVX 27 in. LCD Television
My Olevia 32 inch HD TV shuts offf every 2 minutes by itself. The power just goes off? I turn it right back on and in 1-2 minutes it goes off?
Hi:
Have the power supply checked for bad capaictors on the power board. Also this board can be purchased for around $100.00 at www.shopjimmy.com
Nov 09, 2010 | Olevia LT32HVM 32 in. LCD Television
My Olevia 26 inch LCD works for 2 minutes then screen goes out.
It is most likely the Inverter Board. You can buy them online. The Olevia company got bought out and the only way to have them repaired is by sending it in to a repair shop and they have to send it to this company that is repairing the Olevia models (this is the ordeal I had to put up with) I asked him if I could send it to them but he (in an indian language I could hardly understand) told me I COULD NOT. It is a joke. I repaired my 30" (LT30HV) with the inverter board I bought here ( http://www.lcdparts.net/InverterDetail3D.aspx?ProductID=2510 ). It was $149.00 and they have instructions and pictures on how to repair it. You will have to have basic electrical knowledge as to what goes where when you put it all back together again. Other than that, it took me about 35 min (had to figure out where all the screws were) to take apart, 5 min to take the bad board out, 2 min to install the new one, and 15 min to put it all back together. Good luck
Feb 25, 2010 | Olevia LT26HVX 26 in. LCD Television
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
Olevia 332h comes on for a few minutes then turns off
I have the same problem with my Olevia 332h. The TV shuts off after 10 seconds. I decided to wedge a desk fan in between the wall and the back of the TV. It worked! The TV doesnt shut off anymore. This problem is obviously heat related. I hope this information helps you.
Jun 03, 2009 | Olevia LT23HVX 23 in. LCD Television
Unit powers itself down
does it do this when on battery mode?
or when its plugged in?
i found they do tend to drain quicker the older it gets and that just because of a week internal battery.. i just leave mine plugged in to the cig lighter in my car and i dont have that problem but if you have to use battery power it will drain fast no real fix unless you get a new internal battery and its much easier to just leave it plugged in.
May 22, 2009 | Garmin GPSMAP 172C GPS Receiver
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Olevia LT27HVX 27 in. LCD Television Logo
53 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
