Question about Olympus Camedia C-310 Zoom Digital Camera
On my olympus camera screen there is a blackish colour towards it left following which there are some internal cracks.from where in delhi can i get my cameras screen repaired?
How can I delete photos from my Olympus Stylus when the screen is cracked with internal memory
You will have to hook the camera up to a CPU (with a USB cord) and go in and delete the photos you no longer want.
Nov 15, 2011 | Nikon COOLPIX S230 Digital Camera
Does not work (blue screen)
Olympus Support number,
(800) 622-6372
There is something internal causing the issue. contact manufacturer
Nov 16, 2007 | Olympus Stylus 710 Digital Camera
When I turn on my camera and look at the screen, the colours are off and almost seem like they are bleeding together. However, when I take a picture it's worse - the pictures are warped, colours are very...
It could be 1 of 2 issues:-
1) Make sure all your settings are on Auto and try again. It may be currently set to a specific scene setting which is distorting your photos.
2) It may require a firmware upgrade. That will involve going to the Olympus website, following links to support/downloads and checking to see if there's an update for your camera.
Apr 10, 2010 | Olympus FE-20 Digital Camera
Hi, I'min India from Canada with my Olympus C-770 I have been charging my battery regularly but for some reason the camera stopped turning on-Is there any other battery that I need to know of to check and...
It seems to be defective you can contact the vendor below if you have warranty left of your product..
Vision Solutions (New Delhi)
(Olympus Authorized Distributor / Service Centre)
314 Competent House, F Block, Middle Circle, Connaught Place, New Delhi 110001 India
Tel :(91) 11-3264-9096
E-mail :care@vdpl.in
Feb 16, 2010 | Olympus Stylus 700 / 700 Digital Camera
When turned power on 2/3 of screen is black and then goes away and only left side 1/3 of screen stays blackish and colours mixing up slightly
I'd look at replacing the tcon board at the back of the LCD assembly.
There's currently one on eBay for a reasonable price. It's not mine, but I may also have one later today as I have a 42'' LG ready for disassembly due to cracked screen.
Look for part number 6870C-0094A .
Please vote or comment if this advice helps.
Nov 07, 2009 | LG 42LC2D 42 in. LCD HDTV
LCD screen cracked
Following are the instructions to send your camera to Olympus for service.
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $100.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 05, 2009 | Olympus Mju 790 SW Digital Camera
Olympus D560 Digital Camera LCD Screen
The LCD screen on my Olympus fe-230 camera is cracked and I am trying to find a replacement screen to install. Any ideas where I can find one? Is this something I can replace myself
Sep 19, 2008 | Olympus FE-230 Digital Camera
Multic coloured screen
12b809f.jpgHere is what my pics look like. It was a progressive defect, some good pics, then these in between. Now they are all bad. I found this info below... even though the SP350 is not listed, I am going to call Olympus tomorrow. Good luck!
The camera takes blank images, or the image is distorted
  • There are a number of digital cameras models sold by Canon, Fuji, Konica-Minolta, Nikon, Olympus, Ricoh, and Sony (and possibly others) which use CCDs (image sensors) manufactured by Sony which have had a high rate of failure. Details can be found at http://www.imaging-resource.com/NEWS/1128958202.html
  • Most manufacturers will replace defective CCDs affected by this problem at no charge, regardless of warranty status. This service advisory (technically, it is not a "recall", since recalls are related to safety issues) only applies to certain models and certain serial number ranges.
  • If your camera exhibits the symptoms listed above, we recommend following the link or calling Olympus Customer Service at 800-622-6372. We do not replace the CCDs in Camedia or Digital Stylus models.
Nov 12, 2007 | Olympus SP-350 Digital Camera
Lcd screen broken on Olympus Stylus 700. what should i do???
Sadly there is no "cheap" solution. These cameras are built en mass and repairing them is most times more expensive than teh entire camera. the screens are very fragile and very expensive to by, so the bad news is that it may be cheaper to buy a new camera than to have yours fixed. (crazy isnt it) Still, if you are intent on fixing it, you can call your local electronics dealer and ask who looks after warentee items for them (not that it will be fixed under warentee) but it will give you the name of the company that fixes electronics locally. Just make sure you get an estimate prior to handing over the camera as they will charge a minimum $65 just for looking at it!
Jul 08, 2007 | Olympus Stylus 700 / 700 Digital Camera
Olympus Camedia C-310 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
