Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP6110 OfficeJet scanner squeaks
My HP6110 OfficeJet has a squeak whenever the scanner assembly moves. It appears to be the pulleys that hold the drive belt. I have disassembled & put some silicone grease, which helps for a few days, but it always comes back. Scanner & other printer functions work fine. I am reluctant to replace it, as otherwise it's been very good.
    President:
  • 1,653 Answers
Make sure that the scanner is level and not twisted as this will put unnecessary strain on the scanner frame and pulleys. If your system has springs on the pulley cables then this may be the cause of the problem as they may be worn out or chafing or rusted and need replacing.
Also make sure that the guide rails are not obstructed and brush them out and clean thoroughly and if necessary carefully apply some silicone grease to them.
Also check that the carriage assembly is not bent or twisted which will put unnecessary strain on the drive mechanism and pulleys.
Also check that the pulleys are not bent or the pulley mounts are not bent.
Posted on Sep 12, 2009
When i turn on my car i hear squeaking sound
Belts? Mice? Hallucination? ALL DEPENDS ON WHERE THE "SQUEAKING" IS COMING FROM.
Open the hood. If the squeaking is coming from the area of the serpentine belt, it is probably time to replace your belt. Also, check all fluid levels.
If the squeaking is coming from a particular pulley (such as the air conditioning compressor or the power steering hydraulic pump), there may be a problem with whatever the pulley is attached to.
If the squeaking appears to be coming from outside of the car, you are scaring the mice or hallucinating.
Jul 17, 2014 | 2006 Honda Accord
Squeaking while driving
jack up each wheel and turn them see if noise is comeing from wheel moveing or could be in drive train or worn out brakes squelers going off
Dec 12, 2011 | 2004 Kia Sedona
I have a 2006 ford taurus and its making a squeaking noise wha could that be/
That all depends on when and where it squeaks. If it starts squeaking as soon as you start it there is a good chance that you have either a bad belt or a bad pulley. If it squeaks only when the vehicle is moving then there is a good chance you have a wheel bearing going out. I hope this helps you out, and if you have any more questions please feel free to ask.
Aug 25, 2011 | 1999 Dodge Durango
97 plymouth vourger new belt still squeeks
It sounds like one of your pulleys may be having bearing issues, one way to check this is to go to the parts store and buy some "belt dressing" it is a spray that stops belt squeak. Find a safe spot where you can spray the belt while its moving and only spray the belt. If the belt stops squeaking its just a squeaky belt. If it keeps squeaking then you may have one of your pulleys going bad.
Sometimes pulleys will squeak too if they are just not very lubricated. If the belt dressing works you are good to go, if it doesn't work, go ahead and give the belt area a good spray down avoiding your electrical components. Thanks.
Mar 20, 2011 | Plymouth Grand Voyager Cars & Trucks
Dryer Squeaks when operating. Dries fine; but just squeaks, it comes and goes. Bearings/etc. seem to be ok.
check the tension pulley at the belt. If it has an inspection plate
in the back you can oil the pulley, otherwise you have to dis-assemble to get to the pulley
Jul 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Sounds like your motor and/or pulley assembly are bad. Try turning the drum by hand. If it turns with some effort then you may have a drum bearing going bad. Does the squeaking sound start right away? Or does it start when the dryer warms up? If so then the bearing is going. If you can get to it spray WD40 for a quick fix.
Jul 11, 2010 | Frigidaire Dryers
Squeaking noise in engine. not serpentine belt.
You might have a dry bearing in the alternator. I've had a squeaking noise from them.
May 15, 2010 | 2004 Chevrolet Silverado
Dryer squeaks when clothes are drying
Squeaking can mean bearings going bad or the pulleys needing some oil on them. The pulleys can usually be accessed from the rear of the dryer. The bearings are a different story, you would need to remove outer casing of the dryer to remove the drum to get the bearings behind the drum. I would recommend trying to oil the motor and idler pulleys and if that doesn't fix the problem if your handy you can try to replace the bearings. Its a big job, the bearings are behind the drum and are screwed in from the inside of the drum. In order to remove the drum the casing of the dryer had to be removed, usually the front and the top (the top will sometimes tip back on hinges). After that the drum should slide out with the bearing assembly attached. Installation is the same as removal. {Note: If you find it to be too much trouble, I would just leave it squeak, other than being annoying it won't hurt anything. Also, some dryers have a compartment in the back where you can see the bearing assembly, maybe you can spray some WD-40 in there and see if it stops squeaking. The time you really need to replace the bearings is if your drum is loose, as the bearings have gone bad, not just squeaky}
May 12, 2010 | Dryers
2000 model chevy 3500 5.7 350
try changing the belt it might be squeeking it self or you did not replace the right part that was squeeking or another part was squeeking alnog with the idler
Jan 06, 2010 | 2000 Chevrolet Silverado
HP OfficeJet 6110 All-In-One InkJet Printer Logo
529 people viewed this question
Seeker5211
Seeker5211
