Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I hit the remote opener twice and it opened and closed quickly. Now when I push the remote it only opens three - five inches and closes again.
  • 1 more comment
  • john_conlin Sep 12, 2009
    How can I open and close the door manually. I need to leave the house in 1/2 hr.
    How can I open it manually and then close it??
    I pushed the remote twice because it usually sticks. What happened it opened quickly nad then closed. Now when I push it once it opens about 3-5 inches then closes and opens about 2 inches. I need to leave the house in 20 minutes / is there a manual over ride?
  • 149 Answers
There should be a handle or rope hanging down that you can pull to disengage automatic opener so you can manually open door. check and make sure the door opens and slides easily these are set so if there is any blockage, it stops immediately. Try this before yuu accept solution, ok?
Posted on Sep 12, 2009
  • 103 Answers
Dear it seems that your Remote is transmitting signals well. but at the recieving end. your logic board's hardware or its firmware is in problem. please consult with hardware repairing center.
Thanks
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
Reset key fob
Unlock all doors, foot on brake, all doors closed. Cycle key quickly but carefully on-off appr 10 times until the car honks one time.
Do not turn the key far enough to start the car, just to the 'on' position so the dashboard lights up.
When the horn honks, open and close the driver's door, press any remote button and that's it.
Program another remote? Quickly open and close the driver's door again and push a button on the 2nd remote. That's it.
When you're done, remove the key and the horn should honk 3 times. You're all set.
Sometime it takes more than 10 on-offs to set program mode. Open/close the door, lock/unlock etc, wait 10 minutes, then try again
Jul 22, 2014 | Subaru Outback Cars & Trucks
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman garage door will not close, only a few inches at a time
have a problem which returns every year when outdoor temperatures drop close to freezing. garage door will open only a few inches, then stops. I can close it and try opening it again... same result. After five or six such attempts it typically will open. Interestingly, when I push the switch button mounted on the interior wall of my garage and keep it pushed, the door will open, until I release the button at which point it stops opening.
Dec 19, 2013 | Building Materials
How do you program a replacement key for a lexus es 330 2004
Here are the instructions from the factory manual. They must be followed exactly.
2004 ES330
1. Driver's door open, all other doors closed, key removed from ignition switch.
Within 5 seconds:
Insert and remove the key from the ignition switch twice.
2. Within 40 seconds:
Close and open driver's door twice.
Insert and remove the key from the ignition switch.
3. Within 40 seconds:
Insert the key into the ignition switch and close the driver's door.
4. Switch ignition ON and OFF:
A. Once to program a key remote transmitter code whilst retaining the original codes.
B. Twice to program a key remote transmitter code whilst erasing the original codes.
C. Three times to check how many key remote transmitters are currently registered.
D. Five times to erase all registered codes.
5. Remove key from ignition switch. System should now lock and unlock vehicle
once, twice or five times depending which mode has been selected. One to four
times, slowly, to indicate number of key remote transmitters registered.
6. Within 40 seconds:
Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds.
Within 3 seconds: Press any key remote transmitter button.
System should now lock and unlock vehicle once to confirm registration or twice
to indicate registration has failed.
7. Within 40 seconds:
To program additional remotes repeat step 60 now on each additional
remote you want programmed.
8. To exit programming mode open driver's door or insert key into ignition.
9. Step out of car with remote(s) in hand and test remote(s).
Nov 01, 2011 | 2004 Lexus ES 330
The door won't close with one click, I have to keep pushing the wall button to close the door, remote control won't work except for one inch movement down, the door will open with one click from both wall...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Apr 02, 2011 | Linear Ldo50 Residential Garage Door...
Garage door only raises about two inches then stops.
Check the door springs and also remove the cover from the motor unit and check the drive gear. The door spring could be broken or the drive gear may be stripped.
The sensors only work when the door is closing.
Jun 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
I put in a new battery and the alarm remote does not work
Couple of times when you replace the remote battery, you might have them not working/ responding but just follow the procedure below.
Stand close to the car, hold down the open and close knobs for about 10 seconds. Press them at the same time for 3 seconds; then press the open button as the car opens.
The above procedure is applicable to a lot of car brands. It does not matter how many knobs you might have on the remote fob.
I have carried this procedure out on a lot of brands ranging from Honda, Toyota, Rover, Ford, etc. and it works perfectly well.
Good luck and Rate this.
Cheers
Dec 30, 2009 | 2001 Jaguar XJ8
Programming instructions for keyless remote Does anyone have the programming instructions for 1998 honda passport keyless remote (FCC #HYQ1512R)?
Get into your passport and unlock all doors. Leave drivers door open. Put key into ignition. Turn to ON (not start), then OFF three times within 5 seconds. Close and open the drivers door twice. Turn key to ON then OFF 5 times within 5 seconds. Close then open the drivers door. Press either the lock or unlock button on the remote. Doors will lock then unlock. Press the button again. Doors will lock then unlock again. Close door to finish programming. If it doesnt work, try it again but turn the key faster. You have to do it all pretty quick, but I had it done on the second try.
Oct 03, 2009 | 1998 Honda Passport
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
20 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
