Question about Epson Printer
With my Kodak esp5 connected I cannot get my computer to recognise my ipod Nano when connecting to itunes. I can resolve it by temporarily switching off the USB driver to the printer. I have gone onto the support site on itunes and have worked through all their solutions. The problem appears to be the Kodak printer rather than itunes as itunes and ipod work perfectly with the printer USB driver is disabled. My computer is a Dell dimension 1200 with windows XP.
SOURCE: Adpater USB to PARELLEL, LX-810
Yo también cobro por esa solución.
si deseas la solución te comunicas conmigo para decirte cuanto te costara.
Posted on Aug 28, 2008
ohms
  • 1879 Answers
SOURCE: USB plug in Epson Printer RX595
assuming you properly installed the "printer driver".
disconnect the printer.
check Printer & Faxes for printer icon(s) - delete print queue(s) and the printer icon(s).
open device manager and go to Universal Serial Bus Controllers section.
now we check for connectivity: (treat the printer and scanner as separate devices)
connect the printer, USB Printing support must show up (also check Imaging Devices and the scanner must also show up)
IF USB Printing support shows, windows will create a printer icon in the Printers & Faxes, right click choose properties and print a test page.
ELSE, it's the printer and request for a replacement if it is still within 1 year from the date of purchase
Posted on Feb 26, 2009
SOURCE: scanner not working cannot find scanner WINDOWS XP
Cannot scan  on IMac with Epson Stylus CX3900?
Posted on May 15, 2009
kinkjc87
  • 51 Answers
SOURCE: ''usb device not recognised'' error message on EPSON SX200
Sometimes a disk can be corrupt straight from the manufacturer. I suggest going to epsons website and downloading the firmware from there. If this doesn't work contact the service department from epson for this may be a hardware issue. Hopefully your warranty is still good. Good Luck.
Posted on Aug 18, 2009
SOURCE: Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Posted on Dec 13, 2009
What is wrong with my ipod ao 5th generation
Flip the iPod Nano's "Hold" switch to "OFF."
The iPod Nano cannot be turn on if the switch is set to "ON."
Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF."
Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds.
The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again.
Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes.
Then, try to turn the Nano on.
Update the iPod Nano's software.
Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes.
Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes.
Follow the instructions that appear inside iTunes in order to install the updates on the Nano.
hope this helps
Sep 23, 2012 | Audio Players & Recorders
Won't turn on
Is your iPod fully charged? Sometimes the batteries become so depleted of charge that an accessory charger won't turn it on.
-Try plugging it in to your computer or a wall charger for a while, time will vary but it may turn on.
-If it is not turning on your computer will never recognize it, thus you won't be able to do a restore with iTunes.
-Try a hard restart as well this could help you.
Sep 02, 2010 | Apple iPod nano 4th Generation
My Computer and iTunes does not recognize my iPod
If your computer is recognising other ipods and not yours there is a possibility of somethin being wrong with your ipod.You can always get it replaced.Or else maybe you should check the USB cable you are using to conect.
Finally try your ipod on another computer.
This oughta help you arrive at a conclusion.
and if i helped u solve ur problem in any way...please help me by clicking on the fixya rating..
thank you.
Mar 10, 2009 | Apple iPod nano
Try connecting this ipod to rear USB port on your desktop computer and then try this out
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step
It should work fine
Nov 26, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod not resetting,not recognised by comp
Please load itunes ......www.itunes.com
Oct 01, 2008 | Apple iPod nano
Have you tried resetting it? Press the center (Select) button and the Menu button at the same time and hold for at least 10 seconds or until you see it reset.
hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Apple iPod nano
does other computers recognise your ipod - menial remedy but try resetting it hold down menu and play buttons till u see apple icon then connect........basic but maybe
Apr 19, 2008 | Apple iPod MA446LL/A MP3 Player
Registering & Syncing Ipod Nano 3G
try reformatting the ipod. that might reset it.
Dec 20, 2007 | Apple iPod nano 3rd Generation
Epson Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
