Question about Compaq Presario Notebook
New cq61 212 wireless is not working - Compaq Presario Notebook
  • Stephen Ortiz
    Stephen Ortiz May 11, 2010
    Can you provide more information? Can you see any wireless access points at all?
  • 22 Answers
You must be sure that the wireless service is turned on. This can be a button on the front of the computer or in the area of the keyboard with a wireless symbol on it. Check your documentation for it's location.
Once that is working, then you need to set up a connection to your wireless access point or router. To do that you just go to Control Panel, open the wireless "wizard" and follow the steps as they come up.
You will need information about your wireless network to make that connnection. You will need to know the router's SSID or name of the network and any security code in WEP or WPA settings to allow your wireless to make the connection.
Find this information before beginning the network wizard. Once connected you should be able to access the Internet. If you want access to other computers you will need to do some additional work.
Posted on Sep 12, 2009
2 routers. Can i have two routers within the same workgroup. My wireless router will not work from one end of the house to the other. I need to have more than one wireless transmitter so my laptop will...
Yes you can have the setup in your workgroup in multiple ways.
Solution1:-
The logic will be making your new wireless router to act as a wireless booster which will receive the signal from your old wireless Router and then retransmits the signal.But this needs some extra configuration on your new wireless router
1. You have to select the WDS ( wireless Distribution System) mode in the new wireless router.
2. Set the same SSID on the new wireless router.
3. In the new wireless router config page , search for the wireless signals and select your old router from that list.
The WDS mode tells the new wireless router to send/receive the wireless signal to the old wireless router.
Solution 2:-
Connect your old wireless router LAN interface to a network switch through a CAT5e UTP cable and the new wireless router to another port of the switch (use a cable which can be extended to the other room where you want the new wireless router to be placed).
Configure the same SSID you have set in the old wireless router.
Best Regards
Nov 15, 2010 | Computers & Internet
My wireless mouse is not working
Hello sbregar here, your problem is not very hard try ALL usb connections, if that doesnt work go to HARDWARE under control panel and click new hardware, you go through a wizard and it should work thanks. :D
Feb 14, 2010 | Microsoft Wireless Notebook Optical Mouse...
New Controller wont work with Headset
try to reset button on the both side (xbox and controller))
at same time it will work
for xbox reset buuton on the side censor
for joystick above the battery
Feb 13, 2010 | Microsoft Xbox 360 Wireless Controller
Wireless connection wont work
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
Oct 11, 2009 | HP Compaq Presario 2200 Notebook
Laptop states wireless adapter not installed and configured? worked before.
Oct 11, 2009 | Gateway (802.11usb) Wireless Adapter
Wireless router not working wirelessly
First of all,check the DHCP option in wireless router.If its enable then go to remote user whether PC or laptop enable the DHCP option.
Defaultly laptop have wireless adapter.But IN system doesnot have.SO you need to buy a new wireless adapter..
Oct 05, 2009 | D-Link DI 514 Wireless Router (DI-514)
My wireless adpter is not working
try downloading new drivers for your adapter and
try again .i had the same problem.new drivers worked fine
hope this helps
Jan 18, 2009 | Toshiba Satellite A105 Notebook
Wireless router
Try reconfiguring the wireless settingst that you have in the router. Save the new wireless network settings and try to reconnect to the new wireless network you have just created.
Jan 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Compaq Presario Notebook Logo
379 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
