Question about GE Dishwashers
I was told by a repairman that the seals around the motor swelled because I had gone on vacation for two weeks and not used the dishwasher. He charged $85 to turn the motor manually and restart the dishwasher. The dishwasher is 5 years old. Does this mean I can never leave for two weeks at a time and come home to a working dishwasher?
  • 22 Answers
No. The unit most likely had some debris stuck in the macerator. The seals are water lubricated and its possible that some detergent dried between the seals. Detergent is a lot like glue when it dries. You are probably using the factory recommended amount of detergent which is, at least, twice the amount you really need. Next time you leave for an extended period, run the machine in the Rinse cycle. This will dilute or remove the detergent left in the machine
Posted on Sep 12, 2009
Whirlpool ADG 9999 m
A fairly common occurence with Miele dishwashers is the seal on the pump/motor assambly swells up freezeing the motor.Miele makes tool to free it up very easily,if it doesnt reoccur the seal just swelled and it will be ok once freed up.If it does reoccur the seal needs to be replaced:http://www.diyobd2.fr/wholesale/fvdi-abrites-commander-for-renaultv52-2313.html Any Miele authorized service company will have this tool and could free the motor up within 5 minutes and only a couple uses will tell if it will swell again and need to be replaced.
Oct 17, 2013 | Motorcycles
When I turn it on, it starts to hum but after 30 seconds the red light flashes and the intake/drain light is on. The Miele tech support says to take of the kick plate and empty check for a clog. Any...
A fairly common occurence with Miele dishwashers is the seal on the pump/motor assambly swells up freezeing the motor.Miele makes tool to free it up very easily,if it doesnt reoccur the seal just swelled and it will be ok once freed up.If it does reoccur the seal needs to be replaced. Any Miele authorized service company will have this tool and could free the motor up within 5 minutes and only a couple uses will tell if it will swell again and need to be replaced.
Perhaps Miele could send you one of those tools so you could try and see it the pump seal has swelled up and stuck.
Gene
Aug 12, 2011 | Miele Incognito G858SCVi Built-in...
The inlet drain light and rinse aid light have both come on and the dishwasher is humming but not working. Any suggestions?
Hello Mark,
You didnt say so but i think it is a Miele dishwasher,its the only brand i know of with a Intake drain light
A fairly common occurence with Miele dishwashers is the seal on the pump/motor assambly swells up freezeing the motor.Miele makes tool to free it up very easily,if it doesnt reoccur the seal just swelled and it will be ok once freed up.If it does reoccur the seal needs to be replaced. Any Miele authorized service company will have this tool and could free the motor up within 5 minutes and only a couple uses will tell if it will swell again and need to be replaced, if you contact via their website,they may send you that tool. To use it remove lower rack and pump filter and insert into the side of the pump hole(you will be able to see that hole with the filter removed) and rotate it back and forth at first it will resist then should quickly break free,if it is had to turn the pump/motor seal kit would need to be replaced.
Gene
Aug 07, 2011 | Dishwashers
This dishwasher will drain but not wash m/n g811sci the intake drain lite is blinking
Gene
Aug 05, 2011 | Miele G811SCI Dishwasher
Have a Miele G1022i dishwasher (built in). It makes a humming noise when the power supply is turned on. All the indicator lights flash. Have tried cleaning out the drain and removed water from the salt...
Gene
Aug 05, 2011 | Dishwashers
93 GMC Sonoma 4.3L, no Vortec, I got a Transmission leak that is dripping down onto my front cross exhaust pipe, not sure where it's leaking, got worse after letting it sit for about a week due to steering...
If the transmission is leaking, it generally requires disassembly and replacement of the seal. I have never heard of using brake fluid to swell the seal, and wouldn't know how to get to the seal with that chemical.
Good luck on this repair.
Nov 01, 2010 | 1993 GMC Sonoma Club
LE on display
I just had my LG dishwasher fixed. I told the repair man that LE light was comming on. Even over the phone the repairman said its probably broken wires on the door. Me being in construction for years looked around the door for wires. Anyway the repairman took off 6 screws around the door, took the cover off. You will see about 50 wires taped together. He pulled them aside and visually checked them one by one. Sure enough two were broken in two. He twisted them together put tape and he was gone. $87.50 Still Working!
Mar 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
ASko D3250 fully integrated - hotsteam/water swelling joinery
check the area of leak sounds like seals gone on dishwasher see if seal can be put back into groove posistion
Aug 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Maytag dishwasher has a grinding sound during the
Hi
Many times a complaint of noises ( grinding or scraping ) can be traced to a cracked impeller in many of the common motor and pump assemblies used today. Sometimes a poor washing complaint is common after this wash impeller has cracked. Remove power first before investigating.
The motor shaft has started to rust and swells out and this swelling cracks the upper impeller. Most times a new seal and impeller kit can cure this complaint but sanding and cleaning of motor shaft is required before replacing the new seals and impellers.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Maytag 24 in. MDB9750AW Dishwasher
GE free standing 3200 Dishwasher MD607108A
Had the same problem after not using the dishwasher for a few weeks and managed to solve it.
GE knows about this and has a solution posted at:
http://www.geappliances.com/search/fast/infobase/10000391.htm
Basically, some motor seals dry out and stick. You need to pour some vinegar or citric acid inside the dishwasher to help release them. I poured vinegar (without diluting it) into the dishwasher and waited 30 minutes. This didn't help so I went on to order citric acid online
(http://www.naturesbouquet.com/sea_salt_citric_acid.htm).
By the time the citric acid arrived the vinegar that was left inside for a few days did the work. It is now working fine.
Jul 12, 2008 | Dishwashers
Dishwashers Logo
55 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
