Thin line horizontally across screen
I have a 36" Toshiba tv which is about 7 years old. The screen only shows a very thin line(1/2 inch) horizontally in the middle of the screen. Is this a serious problem? Could it be a major repair? The model is 36AFX61.
  • 4,234 Answers
First of all this set is a CRT based set and thus has what is called a Vertical IC. This is the component that either has failed or has bad connections to the PC board. This is a simple and inexpensive repair. If you are comfortable working inside he set and can solder, you can fix this yourself. First look for the vertical IC. Is will be a small flat IC attached to a heatsink and will be marked TAxxx or LAxxx. Try resoldering the pins first. If that failes to resolve the problem, replace the IC.
If you are not sure whether or not you have the correct IC, post the marking here and I will confirm.
Thanks,
Dan
Posted on Sep 12, 2009
    Problem Solver:
  • 8 Answers
Is the line thin and red? if it is, there is a good chance that it is a bad LCD. Even if it is not the LCD Panel, it has a good chance of being a fairly spendy repair (video board possibly) I would suggest purchasing new if you have a chance, the new TV's are significantly better in picture quality and a much lower price. (i suggest that you stay with reputable brands like sony, jvc, samsung, panasonic, etc.
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
My Sony Bravia KDL 40WL 135 TV has been flashing strange colors for awhile; today screen is black with a thin blue line across the bottom. No sound. Any help appreciated.
The vertical output section circuit has the fault. Contact any experienced service technician. This is not a user repairable fault.
Aug 10, 2012 | Sony Televison & Video
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Toshiba TV (about 7 years old)
You had parts in the vertical deflection circuit failing, most common are the vertical output IC and possibly several capacitors also in the same circuit.
Sep 11, 2009 | Toshiba 36A50 36" TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
My picture is black except for a thin horizontal line
hi When you let the line to long it will burn in!! you need to look into the VERTICAL output section. Most notably check the solder joints on the vert output IC and ESR the caps. If you don't know what any of that means, then take it to a professional. good luck
Feb 20, 2006 | Hitachi 36CX39B 36" TV
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
Electro Med Services...
