Question about Tomtom ONE GPS Receiver
When u turn the gps on, it has a x in a square and that is all it will do
  • 3,153 Answers
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Posted on Sep 13, 2009
Ok so i have pressed the middle of the screen the message no detailed maps that support routing has gone have gone into address it now says no data available and still no maps
The original message of "No detailed maps to support routing" is typically caused by a missing or corrupted map file. It can also be caused by not having the proper map unlock key installed on the unit.
If that problem has been resolved and you can't obtain an address when setting a route, make sure that the map is turned on.
Go to settings, select the map icon and then the map info button. Make sure there is a check mark in the square next to the text that lists the map that you have installed on the unit.
If the map info button is grayed out, then you still have a map issue.
If the square does not have a check mark in it, press the square to place a check mark in the square. This will activate the map.
With this unit, you can put several maps on it and you can select which map will be active or inactive with the check mark.
More map issues are explained here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Jun 08, 2015 | Garmin nuvi 200W GPS Receiver
Garmin 265wt not displaying street names
First, make sure that your map is turned on. Go into settings and select the map icon. Then select the map info button. Make sure that a map is listed on this screen. There should be a check mark in a square next to the map listed. If the check mark is missing, touch the square and place a check mark in the square. If the map is missing, you will not be able to enter in any addresses or search for any points of interest. If you don't see a map listed on the map info screen, then the map is missing and you will need to replace it. The map file name is gmapprom.img and should be on the unit, usually in the folder named Garmin on the units flash drive. If you connect a USB cable between the GPS and a PC, look to see if you can find that file.
Feb 23, 2014 | Garmin Nuvi 265W GPS Receiver
No roads are not coming up when I try to type them in and it will not let me type in any address...
Feb 19, 2014 | Garmin Nuvi 465T Car GPS Receiver
Voice has become almost silent
Tap on the lower left square of the screen. You'll get a slide that allows you to increase or decrease the volume. Turn it up to at least 85% nad try again
Mar 28, 2010 | Tomtom ONE GPS Receiver
How do i control the volume on a xl 340 tom tom
Turn the GPS on. Tap on the LOWER LEFT square on the crseen. This hsould bring up the volume slide, that you can use to control the volume. Slide it to the RIGHT to INCREASE the volume.
Mar 26, 2010 | Tomtom One XL GPS Receiver
Volume is down and I don't know how to turn it up on Tomtom One
Click on the bottom left square on the GPS main screen. You'll get a slide. Slide it to the right to increase the volume
Mar 21, 2010 | Tomtom ONE GPS Receiver
How do i get tomtom to reculate routre
Turn the GPS on. Tap on the LOWER RIGHT square of the main screen. Then tap on the "FIND ALTERNATIVE ROUTE" button. One of the options should be "recalculate route"
By the way, a TomTom GPS will automatically recalculate the route if you make a wrong turn or if you go past a street you should have taken.
Mar 17, 2010 | Tomtom One XL GPS Receiver
Magellan 3200 freeze
there is a little square at the top right corner of the screen. when you first turn it on, press that square to see the satelites it has locked on to, once a few of those turn green (meaning you are locked on by sattelites) see if the map starts workign again. Mine did the same thing and i thought is was broken, but depending on where you are, it can take up to 10 minutes for the map to start working (as it need that astelites to tell it where it is and what is around it) get it? so just try waiting before you put in a destination.
Aug 15, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Navman tcn 320 gps
From the Main Menu press the button underneath the spanner>Demo and deselect the first square if it is ticked>Save.
With your device turned off, press and hold the "OK" button in between the arrows and press the "On" button.
On screen you should see the "Maintenance Menu". Scroll to "GPS menu" using the arrow keys and select it using the "OK" button. Select "Perform a GPS cold start". When this has finished, press the "Home" key twice (the one with the three lines on it). Turn the unit off, then go outside, raise the antenna, and turn it on again. Keep it still for 10-15 minutes and the unit will start to pick up GPS again.
Mar 28, 2008 | Navman iCN 320 GPS Receiver
Waiting for GPS
Feb 17, 2008 | Navman iCN 320 GPS Receiver
Tomtom ONE GPS Receiver Logo
73 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
