Question about Dyson Vacuums
My hose is losing suction whenever i extend it
  • 34 Answers
When you strech it the inside gets smaller causing the air having a hard time to flow through. it's clogged most likely. check the hose and clean it out or i suggest taking it off the vacuum, take it outstide and spray a hose thorugh it and let it dry
Posted on Sep 12, 2009
Dyson DC14 hose won't extend and floor unit lost suction
Sounds like the exhaust side is clogged. Remember a vacuum pulls air into the cavity, but for it to work properly it also has to be able to exhaust the same amount of air it takes in. If the exhaust is blocked it will continue to suck air inside and collapse on itself, which is why your hoses are getting shorter and harder to move. Check the exhaust system for any blockages, perhaps the hole you taped was the exhaust.
Mar 15, 2015 | Dyson Vacuums
Dyson hose does not produce alot of suction when extended.
Hi its Darran at Dyson.
It sounds as though the wand/hose is blocked. with the machine locked in the upright positino, remove the hose from the machine, switch on and test the suction. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If the suction is strong, you will need to check the wand for a blockage. If the suction is still poor, check the hose for a blockage.
You may find it useful to wash the filter as this can sometimes cause a drop in performance if its dirty and it wuold be more noticable from the hose.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Feb 19, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Losing suction in upright position
It's probably your belt. It could be broken or stretched. If broken or stretched, the roller won't spin very well, if at all. Another possibility is that there may be debris blocking suction near the roller. Hope this helps.
Aug 21, 2009 | Dyson Vacuums
Suction
If the wand alone causes a suction loss, there are only a couple of issues:
  • leakage
  • blockage
If it is leakage, remedy the defect or install the wand correctly.  If it is a blockage, you'll have to find and remove it.
Jul 14, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Losing suction filter clean,hoses clear,output blower good,but very poor suction
if the blower is much stronger than the suction, you may have an air leakwhere the cover fits on tank or possibly a warped tank or cover. feel all around the unit for air being drawn in somewhere besides the hose. try it without the hose on and block the inlet for a couple seconds to see if the unit leaks air in. also replace the filter , dont try to clean it, the pores clog and reduce suction and damage motor.
Jun 11, 2008 | Craftsman 17765 Canister Wet/Dry Vacuum
Hose suction Eureka theboss smartvac
There has to be a clog in the hose, Unhook the hose and drop like a big marble in it to see if it comes out the other end.
May 10, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Bissell Lift Off pet revolution vacuum losing suction
You may have a clog in the hose. Unhook the hose and see how the suction is there, if ok, then check the dirt inlet by the brush roll. If suction is low at the hose, then there is a clog in it.
Mar 20, 2008 | Vacuums
Eureka the Boss bagless
Sounds like you have a clog somewhere. Check the filter inside the dust compartment, if is very dirty it won't allow ait to flow thru, Part #62132, DCF-H filter. Check the hose, take it off if you can and drop something in it to see if it comes out the other end, if it doesn't, then the hose is clogged. Check bown by the brush roll, the inlet may be plugged. Also if the belt is more then say 6 months old, you may want to replace it, I am sure it is strertched, part #61120B, extended life belt.
Jan 23, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Hose has suction but will not stretch when turned on
Hi.
I have repaired Dyson machines for years & have never come accross this.
The only way you will have trouble extending the hose is if there is a blockage at the bend where you hold the wand could be a coin which when switched on flips accross & blocks oppening.
Is it easy to slide wand from flexi hose with machine switched off ? You will need to remove wand from hose & push broom handle down to the bend & tap coin out.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
32 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
