Question about LG 47LH40 47 in. LCD HDTV
The audio is not sychronized to the picture - LG 47LH40 47 in. LCD HDTV
  • 525 Answers
Tuner problem .
Posted on Sep 12, 2009
When sychronizing the wii balance board we held the sychronize button down to long and now the wii remote control won't work how do we fix this
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
3. Open the small SD Card slot cover on the front of the Wii console.
4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
7. The blue light will stop blinking and stay on steady once the synchronization is complete
Click here to download repair guide
Jan 05, 2011 | Nintendo Wii Console
What does sychronizing do?
Synchronizing on most mp3 players is used for transferring one or more playlists from a computer to the player, having a connection through USB.
Creating playlists, putting mp3 data in a list with a certain name,
mp3 could be put in a specific order.
The player preserves some space of memory to remember these playlists and the playing order.
Some players support subfolders, but not having the manual for the
MP200 I'm not sure if that will work.
e.g.
MUSIC > music list 1
> music list 2
Dec 20, 2009 | SanDisk Sansa e250 MP3 Player
Gears on my car seem hard to change
if it is grinding when its going into gears it could be the sychronizers. they tend to be the first things to go in manual trannys. if it isnt grinding when its doing it then the clutch could not be fully disengaging when you push it in and that could be it. but if its grinding then i believe its the sychronizers
Mar 20, 2009 | 1998 Ford Explorer
Install mouse
most of the time, dell components (on a dell computer) will have the drivers pre-loaded on the system. follow the directions that should have come with the mouse for plugging in and synchronizing the component. Normally this involves plugging in the "connection" unit to a working USB port on your system and pressing the "sychronize" button on the unit. Make sure your mouse has good fresh batteries in it otherwise the sychronization will fail. You should get anywhere between 4 and 10 feet or range with your wireless mouse if it's operating correctly.
Also, if the drivers are NOT preloaded on the system, there should be a driver disc that came with the mouse, insert it and install the drivers for your mouse on your computer prior to following the above advice.
Jun 28, 2008 | Dell wireless keyboard and Mouse ( t0179)...
How do I load pics onto my keychain
In my opinion I have had a similar problem and I hope this help you out. When I frist started saving pictures I was putting them into the wrong folder and it was asking me to format the disk too. It was asking me to format my camera so If you do have a camera and are trying it make sure you don't have any pictures on your camera and then plug it in a format the disk on your camera, I believe If you put your pictures in another folder and try it, Are you trying to print,save to disk, ect. Or just looking to view them, If you format your cameras disk drive and it still don't work, please feel free to contact me at bear340cid@yahoo.com I will get somemore info and do what I can to figure this issue out asap. Thanks bear001
Dec 12, 2007 | Computers & Internet
Screen display
To find the source of this problem, you must test each unit on another unit. Try testing your dvd player on another television and try using your television as a television and check it out using another dvd player. check the operation of each unit. If both unit seem to be working fine with the other units, then your problem may be with the cable connections between the units. Try moving them around while you are experiencing the problem ito see if the picture changes back to normal if this happens then you may need to replace the cables or separate them so that they cannot interact with each other causing noise on the picture.. If this does not solve the problem consult you owners manual for both products on how to sychronize the signals between the two products. Try to synchronize them to each other and see if this improves the picture quality. If this does not work you should consult your ownsers manuals for the customer service number and get technical assistance for you problem. You can contact TruTech technical service at these telephone numbers : 1-800-252-6123 and 1-888-252-6252. I hope this helps you with your problem.
Nov 27, 2007 | TruTech PLV16320 Television
This thing is messed up
after player connected, try to open it in "My computer", and it must show as a removable drive, just re-format it windows and see how much free place it has then
Aug 23, 2007 | Insignia NS-DV2G MP3 Player
White Noise Sound
Your problem is somewhere between the tuner and video detector circuit. The signal entering your TV carries: video,red color,and blue color as well as sychronizing pulses for color and horizontal and vertical deflection ( actually vertical sync. is derived from horizontal sync.) along with burst pulses to synchronize the color. After all these, the sound is an fm signal entwined with a pilot signal for stereo audio. WHAT a mess! After the audio passes through all this, it is detected and sent to the audio processor. If any frequency has drifted away from it's value then you loose the sound. SO... your problem could be in any of the tuned circuits or in the audio processor IC (chip). Any component changing value could creat this problem. Most likely the audio processor IC. You'd need to have the set checked out by a tech to find your problem. Stargazer
Mar 11, 2007 | Proscan PS32600 32" TV
LG 47LH40 47 in. LCD HDTV Logo
109 people viewed this question
Computer Repairing
Computer Repairing
