Question about Little Giant 115V 60Hz Condensate Removal Pump 554405
How do i wire the leveler switch to the heater little giant condensate pump
Plsma steel cut torch
Posted on Sep 13, 2009
VCMA-15 Have a catch pan overflow switch which goes in series with the thermostat circuit, but there are two low voltage wires coming from the pump and these have been connected together since installation...
You should have it wired in series with the wire on the 'R' terminal of the control board to the thermostat. Usually the red wire. This will shut down the complete system if the pump fails. The pan switch should be wired this way also, so they can both be in series with each other.
May 25, 2011 | Little Giant VCMA-15ULT 1/60 HP 3/8"...
How do I wire the safety overflow switch to my furnace humidifier thermostat? I have a Little giant VCMA-20ULT and a Aprilaire 700.
The overflow switch needs to be wired in a manner that interrupts the HOT (black?) side of the wires going to the water inlet valve or it's circuit.
Feb 28, 2011 | Little Giant VCMA-20ULT 80 GPH - Automatic...
I had a new hi-eff. furnace and A/C system installed three years ago. The furnace humidifier drains into a little giant condensation pump. I just noticed that the pump cycles on and off very rapidly when...
Depens on what type of humidifier you have there are tank type like lobb or water over waterover will make the pump run every time the lobb wont it has a tank with water going up in price lobb wa2 is better
Feb 27, 2011 | Little Giant Condensation Removal Pump...
My Little Giant, Model VCMA 15UL, condensate pump is cycling on and off very frequently. It starts and runs for about five seconds and then stops. It repeats this cycle about every 30 seconds. When this...
Thank you for posting your question here on Fixya.com.
Replace the check valve that is part if the discharge hose barb. When it fails the water trapped in the vertical section of the tube comes back into the tank and cycles the float on again causing what you describe. The best way to confirm this would be to watch the water level as soon as the pump shuts off and see if it climbs without any other source of water coming into it. If it is not rising then the issue is with the float itself and is not worth fixing; replace the unit in that case.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowmotor.net. Positive feedback is appreciated once your problem is solved!
John
Feb 15, 2011 | Little Giant C20ST Condensate Removal Pump...
My old pump has the brown and blue wires connected
first do not change the factory wiring, what voltage is the pump wired for, what voltage is supplied to the pump.
then we figure out the rest
also what do the instructions say about the pump
NO stands for normally open contact-which means during operation is open which means off.
will be glad to help 865-888-1220
Mar 02, 2017 | Little Giant 115V 60Hz Condensate Removal...
Little Giant 115V 60Hz Condensate Removal Pump 554405 Logo
138 people viewed this question
Top Little Giant Electrical Supplies Experts
Mike
Hippy_dd
Are you a Little Giant Electrical Supply Expert? Answer questions, earn points and help others
