Question about RCA HD52W56 52" Rear Projection HDTV
My tv has a vertical line through the middle and it still has sound
  • 4,234 Answers
The problem here is with the VERTICAL circuit and is usually easily fixed. Your posting is listed under an RCA model, can you please confirm your model number so I can provide you with the details about parts etc.?
Thanks,
Dan
Posted on Sep 12, 2009
  • ABRsvcs Sep 13, 2009
    Palaboy is correct and I am wrong. The problem is likely to located close to the HOT. I misread the posting.
    Dan
  • 525 Answers
The problem is in horizontal tv circuit. Must be done by a technician
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Whtie line in middle of toshiba tv cx32h60
The vertical sweep output has failed. Check the vertical output section circuits for any loose solder terminals. Check all the solder terminals of the vertical output IC. Resolder all the suspected solder terminals by applying a little more solder. If these do not help you, replace the vertical output IC.
Jul 07, 2012 | Televison & Video
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
White line through the middle of the screen
If it is just a vertical fold over then resolder its pin, if not work then you have to replace the vertical IC. Usually you can still hear sounds from the channel program it is tune. This applies to a crt type tv.
If you are not inclined in electronics.Its better to have it check by the expert. Live nasty voltages inside.
May 30, 2009 | Televison & Video
Problem with tv
The problem is sometimes caused by the vertical output integrated circuit (IC) failing, but usually it's bad solder connections. If you or someone you know is comfortable with electronic soldering, a few minutes spent resoldering the IC pins to the circuit board will often solve the problem. Failure of these connections is common because the IC gets quite hot (and it's mounted on a metal heat sink). The heating and cooling cycles cause the solder joints on the circuit board to crack. You can usually see the trouble with light and a magnifying glass; gray grainy joints instead of shiny connections, and often visible ring cracks around the pins.
Mar 31, 2009 | Konka K1938U 19" TV
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Blank screen except for a vertical grey line through the middle
The horizontal sweep signal to the yoke is bad. Since other problems exist, the problem may be in the IHVT HI voltage transformer area. Check for bad solder around the IHVT pins and yoke plug. I hope this helps. Lee http://www.CrazyComputers.com
Jun 22, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
RCA HD52W56 52" Rear Projection HDTV Logo
831 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
