Question about Kenmore 22422 Top Load Washer
When we turn on the Kenmore wash machine, the water flow is weak and takes forever to fill the drum up.
  • 4,070 Answers
If your watr pressure is good then there is a screen filter in the hose that connects to the water inlet valve on the washer. Unscrew the hose and look in the end. It may be clogged with sediment etc.
Posted on Sep 12, 2009
Kenmore washer water not filling
there is a inline mesh filter at the tap end of the hose but it is more that likely that the tap washer need replacing
it is possible that the inlet solenoid valve is not operating properly
if you have separate hot and cold water hoses and taps then either tap should produce a full flow when set if no taps get a full slow when selected , indicates a problem power board
Nov 05, 2017 | Kenmore Washing Machines
I have a kenmore series 80 washering machine. The washer begins the wash cycle mormal. About half-way through the wish cycle the washer begins to fill with water again. It will fill with water until to...
the water level control has gone bad,its located in the top of the washer control panel,four philips head screws gets you in there,make sure you unplug the machine,it has a rubber hose,and four clip on wires,one 1/4 inch screw holds it in place,its job is,it works off of air pressure from the rubber hose that comes from the washer drum,if it don"t read the back pressure from the drum being filled it will over flow.good luck
Nov 19, 2012 | Kenmore 24032\24036 Top Load Washer
My washing machine takes forever to fill with just cold water. the hot water runs into the machine good, but when i use just cold water it rickles in.
The solonoid coil that opens the cold water part of the inlet valve is weak and the water valve could be replaced to fix that trickle of the cold water. The hot and cold both fill trough the same water inlet valve, with two solonoids on it ..one for the hot and one for the cold.
GENE
Oct 08, 2011 | Amana Washing Machines
When my son's new Kenmore washer is filling up it starts off with the water rushing in like it should but after about a minute the flow falls back to almost nothing and it takes forever to fill up.
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 12, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My washing machine is taking a long time to fill. it just started doing this. the flow of water is very weak and as it is a super capacity washing machine it takes forever to fill up.
Have you checked the inlet filters on the water hoses ?
If you unscrew the water hoses from the machine, and look inside the connections on the machine, you should see the filters - they are usually a plastic "cage" supporting a gauze or fine mesh. These can be pulled out (you may need tweezers or fine nosed pliers) and washed under a running tap.
If this doesnt cure it, check that the water supplies where the hoses connect to your house plumbing are actually fully on and flowing properly.
Otherwise, there is probably a fault with the solenoid valve(s) on the machine that controls the flow of hot water in to your machine.
Nov 08, 2009 | Maytag Dependable Care LAT9206
Slow to fill on most cycles, top loader. Kenmore washer takes forever to fill to the level needed to wash clothes.Model # 110 (92284800), Serial #CC0523352.
Turn off the water. Remove the cold water hose from the machine. Clean the sediment out of the screen on the water valve.You can remove the screen with a bent paper clip. Replace the screen after cleaning.
Aug 24, 2009 | Kenmore Washing Machines
My kenmore washing machine takes forever to fill up
The screens on the hot and cold water ports on the back of the machine are clogged with dirt, assuming you have good water pressure coming to the washer. Turn off hot and cold water faucets, take hoses off at rear of washer (remember which one goes where). You will see a round screen inside the hot and cold ports. Remove them and clean. Sometimes if they are old you may need to buy new ones.
Jul 06, 2009 | Kenmore Washing Machines
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
51 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
