Question about Honda Water Pump Honda Engine
2" honda trash pump haw no presure
My pump start and run ok , but haw no power to pump
any water
  • 57 Answers
Maybe you trashed it. Take the cover off and look for any debris in the impeller. Also make sure you don't have any air leaks on the intake side of the pump. If the pump is ok and the engine bogs under load then the high speed jet could be out of adjustment or junk i the carb. Remember don't run the pump dry. You can also try adjusting the jet while it is running. Remember turn the needle slowly until it runs better.
Posted on Sep 12, 2009
Honda 160 homelite pressure washer 2700 psi no pressure
Water comes out the nozzle, but low pressure? ( more than when the motor is not running)
I would check the check valves and the unloader.
If the amount of water coming out the nozzle is the same when the motor is running or not running.
Either the key that connects the motor shaft to the pump shaft is sheared, or the pump is trash.
No water comes out the nozzle would indicate a clogged inlet filter or blockage at the gun valve or nozzle.
May 05, 2014 | Homelite Pressure Washer. Honda 2700 psi...
Does anyone have a answer as to why all of a sudden theres no water and presure coming out of my jet washer
If there is no water from you power washer it is because the is no water going in. Check fitting is connected properly. When you pull the trigger and the machine is not running you should get water coming out of the nozzle That shows that water from the tap is passing through the machine. As to no pressure that will be a fault in the regulator valve that is not reacting to the trigger setting and allowing the pump to build up pressure. It is still reading as if you haven't pulled the trigger
Feb 24, 2013 | Honda GCV160 Engine
Not getting gas won't start
Will it start on starting fluid if so check your fuel rail for presure No presure check your fuses if fuses are ok Check your fuel filter Do you hear the pump running you may have a bad fuel pump
Feb 27, 2011 | 1990 Ford Econoline
1994 yamaha 115c won't run at full power,why?
If you have water/trash in bowls, it comes from the tank and you need to drain and clean tank.
Check the fuel pump to make sure the diaphragm is ok and clean out/replace the lines and primer bulb also. a 10 micron water separator/ fuel filter would be a good investment
Probably will need to pull and clean carbs. Flushing will not remove trash fro jets/passages.
Nov 24, 2010 | Yamaha Boating
Honda Trash Pump Model WT30X Stalling - 8hp engine runs for approx 5 seconds that shuts down, restarts after I hear a relay click ? oil is fine - so I do not believe that it is an oil pressure...
Their is an oil level sensor that lasts around 3 months of use. unplugging it would solve your problem But replacing it is a night mare. and if your oil runs out It's all over. if not the oil sensor, and your spark is constant Check your fuel system for water and debrie. Those pumps can run dry all day long.
Apr 06, 2010 | Honda 8 HP Engine
1986 sei 1200 goldwing It will start from ignition on,fuel pump runs for a few seconds,fuel light goes out,every thing normal-no LED diagnostic lights.When it starts it will run for about 3-5 seconds &...
check the fuel filter it sounds like it's pluged and causing too much back presure this is causing an over load in the fuel pump causing it to stop working or to presure lock
Aug 03, 2009 | 1986 Honda GL 1200 Aspencade Gold Wing
No fuel presure pump dose not run
start by checking the fuel pump fuse and relay if both those are good look to see if you have got power to the pump if yes you may need a new pump
May 17, 2009 | 1998 Chevrolet Blazer
I have a honda 4hp trash pump have problems starting its not getting gas from carb to spark plug
oil is on the spark plug , so I change it and replace it with a new one and it did the same thing. This on a honda trash pump.
Apr 08, 2009 | Honda Water Pump Honda Engine
Rayburn boiler runs heating system, radiators tepid
What is the temp at the boiler? there is a temp/ presure guage it should read 160-180F. If that is OK then check the circulating pump. When the thermostat is turned up you should hear a little water moving through the piping as you have adjusted the system. If you hear nithing circulating you may have a defective pump.
Good Luck, Phil
Dec 10, 2008 | Water Heaters
Honda Water Pump  Honda Engine Logo
160 people viewed this question
Top Honda Tools & Hardware - Others Experts
gbob59
John Loiselle
Level 1 Expert
Bill Boyd
Are you a Honda Tool and Hardware - Other Expert? Answer questions, earn points and help others
