Question about Canon PIXMA MX300 All-in-One Printer
Unable to configure for sending Faxes from PC. I
Unable to configure the machine for sending Faxes from PC. I have BT Broadband connection and the question is how do I connect the machine with the BT Hub
Hi, since having a new BT home hub, my inspiron 6400 will not connect wirelessly unless I do a 'repair' with it. Sometimes it detects broadband but wont connect wirelessly. My son changed the channel...
Most people have to just work out the configuration by them selves BT do offer a lot of support (0800 022 33 22) Their equipement is pretty good and widely used.
By the way the most least used channels are 1,6,and 11 there might be a default but these are the most complete channels which do not overlap(RE;
cnannel 1]--2.412 Centre frequency(ghz)
channel 6]--2,437
channel 11]-2.462
Mar 14, 2011 | Dell Inspiron 6400 Notebook
I have a BSNL boardband connection, can you tell me how can I configured?
The internet connection that you use doesn't matter with WinFax, since WinFax requires a fax modem to send and receive faxes. You cannotuse your broadband modem to send receive faxes with WinFax PRO. http://www.getfaxing.com/forums
Dec 10, 2010 | Symantec WinFax Pro 10.0 for PC
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
Have two fax machines on two seperate broadband lines, both lines also serve internet/mail access which is working fine. Both faxes exhibit periodic/intermittent transmit and receive problems. Have had...
You can not send or receive faxes with any consistency on Broadband lines. You need an analog telephone line for these to work. Fax machines work on analog technology.
Jun 30, 2008 | HP Office Equipment & Supplies
Unable to send the mails
it seems that u r reciving mails bt unable to send email. to get rid of this problem i belive u need to change the setting for SMTP setting which is not configured in ur case i belive so. for step by step configuration click on the url and follow the procedure.
http://mail.google.com/support/bin/answer.py?answer=76147
. i hope i will b helpfull.
Jun 21, 2008 | Microsoft Outlook 2003 for PC
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Cannot send or recieve faxes
You cannot send a fax on a broadband connection, they should have given you a splitter, if not get one, the splitter is a small box like thing, it has two telephone sockets on one side and one socket on the other, the telephone line from the wall is connected on one side, on the other side you have to connect your adsl modem in one and your telephone in another socket, Usually the sockets have descriptions on them specifing which decive should be connected to the socket.
Now you should have a dial up modem(56Kbps internal or external modem) connect this modem to the socket which specifies, Telephone. Configure the modem. configure yor fax settings to use this modem. Now you can send your faxes.
If your ISP does not support dial-up then you cannot use it to send faxes.
Post back with your results.
Jan 04, 2008 | Computers & Internet
Canon PIXMA MX300 All-in-One Printer Logo
44 people viewed this question
old marine
old marine
