Question about Refrigerators
I have a KA fridge with ice maker. the ice maker cycles but does not fill with water. have changed the inlet valve but no change. any ideas what to do next
  • 4,070 Answers
See if the water inlet valve is stopped up with ice, blocking the water. This happens when the water inlet valve leaks.
Posted on Sep 12, 2009
Why is ice maker making small cubes?
Low water pressure can make small cubes.
Feb 14, 2016 | Refrigerators
My BI95 ice maker freezes and has water flow, the mould maker fills, the water continues to run into the bucket and it freezes solid. I changed the mould maker and water valve. The problem remains
If water keeps running after the fill cycle is usually indicates a bad fridge inlet valve. This valve controls the amount of water going into your icemaker. It is found where the water line goes into the fridge, usually in the back of the fridge at the bottom. You would need to cut the power to the fridge, turn off the water supply going into the fridge and remove a panel to get to it. You can check out online what a fridge water inlet valve looks like so you can identify it. It usually has 1-2 water lines going into it and 1-2 wire harnesses attached. You can buy new ones at a appliance parts store or online.
Sep 28, 2015 | U-Line Icemaker
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Icemaker won't fill tray,
Was the inlet tube frozen. If so your water inlet valve on the back where the water supply comes in is probably leaking and when the water reaches the freezer it freezes, blocking the inlet tube. Replace the water inlet valve.
You can Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Samsung RS2630WW Side by Side Refrigerator
Water is not filling ice cube maker
Is the freezer cold enough? Should be close to 10 degrees.
Once the ice mold has water in it, it may start cycling when it freezes.
If the fill tube is blocked with ice, the water inlet valve is leaking and needs to be replaced.
Aug 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water will not come into the ice maker and the filter needs changing. Even though the filter needed changing before, water has never stopped coming into the ice maker. The line seems to be clear. Any...
Replace the water inlet valve after making sure the tube which fills the icemaker is not frozen . If it is , replace the valve anyway . The valve is the piece which connects to the line to the wall on fridge .
Jul 29, 2009 | Whirlpool GS6NBEXR Side by Side...
I just replaced my icemaker on a kenmore fridge #2537481240g I heard the soleniod(water valve) enage and the ice maker has gone thru 3-4 cycles but still no water? any suggestions?
Fill tube above ice maker may be frozen. Remove the fill line from the back of the unit where it comes out of the solenoid valve, force ice maker into a harvest put hose in a bucket and see if you get any water when it actuates the valve, the valve may have a clogged screen or not opening at all. If you get water, then you have a frozen fill tube
Jun 13, 2009 | Refrigerators
Ice cube tray isn`t filling with water but I have water on the door dispenser.
Hi, Check the inlet tube that comes through the back wall into the ice maker. See it has froze shut.
If there is ice in the tube, thaw it out and let the ice maker cycle. Plan on changing the inlet valve if the tube is plugged.
If the inlet is not plugged, let the ice maker cycle and listen for or test the valve for 120V. If there is a buzzing sound or you are getting voltage and no water, remove the tube frrom the valve that leads to the ice maker and see if water comes out of the valve.
If no water comes out of the valve, change it.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Freezers
Ice maker wont fill
Hi, It sounds like the inlet valve needs changes. Could be the plunger inside the solenoid is not lifting to allow water through. If you remove the line going to the ice maker off the inlet valve, try and cycle the ice maker and put the inlet valve over a bucket to see if water is coming out when it gets voltage.
I hope this helps.Please let me knwo if I can assist you further.
Thanks
Vic
May 31, 2009 | Kenmore 53502 / 53504 Side by Side...
Kenmore Ice Maker Not Making Ice
the water that is frozen in the fill tube could have come from the old water valve that you replaced ,you got to get the ice out, the easiest way ,though not the fastest ,is to unplug fridge for 24 hrs . and leave the doors open to let it defrost, the plug back up and hopefully in 5 or 6 hrs you'll have ice
May 20, 2009 | Freezers
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
