Question about HP Photosmart C5180 All-In-One InkJet Printer
Can't print in black because no yellow
Any solution to this issue?
    President:
  • 1,653 Answers
Yes replace the Yellow cartridge. This is because the printer will construct the black colour as a mix of all the colour inks installed in the printer.
However, on the printer preferences you can see when you print a document from an application by using the FILE tab and then selecting the PRINT option then go to PRINTER PREFERENCES there is an option to select printing in Greyscale or Black & White only.
Also if you are printing text from an app such as Word make sure that the text is actually 100% black as if it is not then the printer will automatically ignore the black ink cart and try to mix it from the colour ink carts just as it would when printing an image.
Posted on Sep 12, 2009
I am getting message "the
More black/yellow print head failure we observed in this series, no remidy for this issue replace the print head..
Sep 23, 2011 | HP Officejet Pro L7680 All-In-One Printer
Hi, my printer is not printing. My black cartridge was low and i just changed it. With the new cartridge in its printing very pale grey instead of black and also very patchy printing. I also changed...
Lexmark recognizes that some of our inkjet all-in-one customers may be experiencing issues with their print quality. We take our customer user experience very seriously, and we strive to ensure that each time a customer prints using a Lexmark device the page is crisp, clear and up to the highest standards.
However, if your device is displaying a 'printhead error' on the hardware and/or you are suddenly experiencing a print quality issue, please contact the Lexmark Technical Support Center at 1-800-539-6275 or point your browser to http://bit.ly/lFKDzs for online technical assistance.
Aug 22, 2011 | Lexmark Prospect Pro205 Wireless...
I have a HP Colourjet 2600n which has worked well for 12 months plus. However it has just started printing with thick black smudges along the left of every page. It looks like there is yellow powder...
If you have BLACK Marks on the paper the YELLOW roller does not need to be cleaned usually.
To clean the yellow toner off the roller use a DRY lint free cloth. For this issue my suggestion for a resolution to the Yellow toner issue is replace the toner. They are not supposed to leak in the first place.
As for the BLACK tone on the left of the page you most likely have a Fuser issue causing that.
Jul 27, 2009 | HP Color LaserJet 2600n Printer
Printing yellow for black
Hi Jan,
Can you confirm that you are using a CIS or non-HP cartridges with this printer?
It sounds a lot like the printhead has reached a clogging point where sediment has built up in the black portion and loosens enough to printer a few lines before it re-asserts itself again.
Based on my experience of this printer, if you're using a non-HP delivery system for ink then you should consider replacing the black ink with a dyebase alternative instead of pigment.. Replacing the Black/Yellow printhead and running a number of test prints to purge the pigment ink in the printhead should then result in a clean and more reliable printout in future.
One other vector for problems is the cleaning area and I've found that this can become soiled with excess ink causing cross contamination within the inks of one printhead. As yet I've not found a reliable solution to counter this sort of issue.
Hope this gives some clues and hopefully some ideas of a fix.
Martin
May 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printing error message: cartridge problem.tri-color.I wasn't even
hi,
its becoz even if ur print contains only black text in it, while printer printing in black it needs a cyan or yellow ink to give very clear print out. work around for this issue, go to the printer icon and right click and go printing preferances and change the option to print only in blak or print only in gray scale. it should resolve ur issue............
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet J4580 All-In-One Laser...
Won't print colour copies it comes out in yellow
Try replacing the Yellow/Black Printhead of the All-in-One. I am sure the issue will be fixed.
Jan 08, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
HP officejet pro l7680 all in one
Most likely the print head has failed and the black is not printing which is causing the printer to have issues. Talk to HP as I guess printheads have warranty or simply change the yellow/black printhead. Or if all of these fail give the machine to HP to get you a new one as this is not right. I hope this helps.
Nov 18, 2008 | HP Officejet Pro L7680 All-In-One Printer
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Only print on black and yellow
did you use generic ink? those ink will clog the ph espacially the mag + yellow channels.
do use original brother ink carts because these contains special cleaning fluids!
Mar 20, 2008 | Brother MFC 210C All-In-One InkJet Printer
Yellow Lines on every print
If the optics are clean (use lint free cloth on 4 rows of black thingys underside of lid)
Then it sounds like the yellow drum needs to be replaced, when printing in word I'm guessing that you have it set to B/W prints hence no colour is engaged, no lines
Oct 17, 2007 | OKI C5100n Laser Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
122 people viewed this question
Seeker5211
Seeker5211
