Question about Mantis Tiller
Mantis tiller wont start. Turns over but will not stay on. Had it repaired at local lawn mower/power tools shop. Carburator adjusted. Worked for an hour. One month later, same problem.
  • 85 Answers
See if it is leaking fuel, could be cracked fuel lines or a plugged fuel filter.
Posted on Sep 13, 2009
Won't start
Remove carburator also remove diaphragms and gaskets, soak carburator in carb cleaner over night, then spray dry. put back together with new diaphragms and gaskets. Triky part is next H-red ( high) L-white (Low) adjusting screws remore plastic caps to allow u further adjusting. This will get your tiller back up and running, let me know if it helps or any questions you might have
Apr 22, 2011 | Mantis 2-Cycle Tiller
Im just getting out my mantis and im having some problems. I have checked the tines and they are free of weeds and dibris. When I give the machine gas it acts as if it is binding up and does not...
The carburetor is having some issues. I would go to a repair shop and see if they can adjust it for you. On certain carburetors it requires a special tool to adjust it. I believe that the Mantis Tiller has an echo engine on it. If you cannot find a local dealer for your Mantis then I would try for an Echo dealer.
I hope this helps. :)
Apr 12, 2011 | Mantis 2-Cycle Tiller
7222m mantis tiller need a diagram or set up adjustment for the carburator
Set low speed jet 1 turn out high speed 1 and a quarter turn out
Sep 27, 2010 | Mantis Garden
I have a briggs and startton lawn mower and the
under the pull cord housing is this little arm that pulls out when you pull the cord. Thus, the little arm locks into place on the pulley and turns the flywheel which turns the motor over. The arm inside may need to be greased and worked a bit. Sometimes the springs do fall off
Jul 10, 2009 | Mantis 2-Cycle Tiller
My mantis will not stay running unless the choke is full on
sounds like the fuel pump diaphram in the carb. you need to either be familar with it or take it to thae shop to replace
Jul 06, 2009 | Mantis 2-Cycle Tiller
It was working fine last year, and I only use it annually to dethatch and aerate my lawn, and very little tilling. I purchased every part available for it, though. This year, I noticed that my son had left...
Take off the air cleaner and spray carburator cleaner into the carburator. If this doesn't get it going, you'll have to take the bowl off the carburator and clean the insides too.
Jul 03, 2009 | Mantis 2-Cycle Tiller
Mantis tiller won't run at high rpm
check the carburator, it sounds like a main jet is clogged or the carburator is dirty. Is the air filter clogged? Is the motor under strain?
Mantis Tiller
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Nov 13, 2008 | Mantis Tiller
Mantis Tiller Logo
321 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
