Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool LSQ8033 SW Top Loader Washing Machine where can I get the schematic drawing from as its not spinning and would like to know if its belt driven or direct drive
    President:
  • 3,113 Answers
  • honeymokey
    honeymokey Feb 18, 2010
    myapplianceparts.com
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
Slinteriors
  • 8617 Answers
SOURCE: Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Posted on Mar 27, 2008
  • 2318 Answers
SOURCE: Whirlpool Top Load washing machine no spin cycle
Click here for more info on the direct drive appliances.
Posted on Aug 28, 2008
jsrock516
  • 5911 Answers
SOURCE: how to take apart a Whirlpool top loader washing machine
If you have not taken the exterior washer casing off, the first steps will explain how to accomplish this:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Once the casing is removed, you should have full access the the washer interior components. Since you have mentioned you taken the "internal post" off (I'm assuming this is your agitator), I will spare the steps in involved in accomplishing that task.
Next, follow these series of steps:
1. Remove the tub ring. This is the cylindrical donut shaped ring attached to the top of the wash tub. This ring needs to be removed in order to accommodate the removal of the inner spin basket. The tub ring comes off by placing a screwdriver under the series of the tabs that hold it in place and GENTLY prying them up until they release. Be careful not to break off the tabs, or crack the wash tub.
2. Remove the spanner nut that is under the agitator. This holds the inner spin basket to center post.
3. With the spanner nut removed, the spin basket should lift straight up and out. Sometimes the basket will stick to the center-post and may required some "coaxing" to get it free. This can be accomplished by grabbing the rim of the spin basket and prying up on one side, then the other, in an attempt to rock the basket side to side.
Searspartsdirect.com has excellent exploded view diagrams that you can use as a reference. Simply type in your model number and look under the "Agitator, Basket and Tub" heading. The tub ring gasket, I mention below, is listed as item 6. Appliancepartspros.com also has these same drawings.
Some things to consider:
If you remove the tub ring, it is recommended that you replace the seal on the ring before reassembly. Once the tub seal is broken, it can leak if the seal is not replaced.
When reinstalling the exterior cabinet, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have questions, or need further assistance, please let me know. I hope this helps you.
PS What is the reason for removing the spin basket? Anything else I can help you with?
Posted on Jan 17, 2009
  • 111 Answers
SOURCE: Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
Posted on May 21, 2009
My machine is not spinning what may be the problem
depends on what brand and type of unit... is this a front loader a top loader and what brand.. is it direct drive or belt driven.... if it is belt driven could be a bad belt or pulley...if it is direct drive such as a top load whirlpool ,kenmore,roper, you could have a bad drive coupling which is located between the motor and transmission under unit.... if this is a front loader there are numerous items it could be example a motor controller board, main pcb board.
if everything is working but the spin mode and this is a top loader unit may want to check the lid swich that will cause the unit to not spin.... hope this helps kinda a vague description of your probelm....good luck and give me a vote i need them....
Jan 03, 2011 | Washing Machines
My whirlpool top loader extra large washing macine
Many late model washing machines use a direct-drive system to agitate and spin. They don't use belts or pressure wheels to transfer power and motion from the motor to the transmission. The motor is coupled directly to the transmission. If the motor is running and there is no agitation or spinning of the tub, the culprit is usually a plastic coupling between the motor and transmission or the transmission itself.
Aug 07, 2008 | Washing Machines
I was washing wool that has a lot of lint and the washing machine stopped spinning and smelled like hot rubber. Is there a filter to clean in the washer?
The burning rubber smell is probably the belt. It is probably broken into. Remove the front of the washer on a top loader to access the belt at the bottom where the motor is.
Dec 29, 2010 | Whirlpool Washing Machines
Why my whirlpool washing machine wont spin model # LXR5432KQ0
If this is a Whirlpool manufactured TOP LOADER washing machine, a no spin problem can have several causes. Most commonly, this is caused by either a lid switch malfunction or a broken motor coupling. The following link explains how you can diagnose the problem and repair it yourself:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
Read through the link provided and let me know if you have any questions. I have included parts resources and instructions on how to replace each part as well.
The part number for a replacement lid switch is 3949247. The motor coupling part number is 285753A.
If you have questions, please post back and let me know. I hope you find this information helpful.
Apr 14, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool wont go in to spin turned machine to
might be a bad lid switch or the couple between the motor and trans could be broken
Feb 27, 2010 | Whirlpool Washing Machines
My whirl pool washing machine no longer spins. I just stopped on day. I can hear the motor trying to turn the drum but it doesnt.
Hi. This is a possible broken belt. You will need to access the drive assembly to confirm. The symptoms you have posted will often lead to a separated belt.
NOTE(IF this is a top loader, and you are hearing noise during the spin attempt, this will lead to failed motor coupler. Please disregard this note if the unit is a front-loader)
Oct 08, 2009 | Whirlpool Washing Machines
How to change the belt in my whirlpool washing
It's probably the washer transmission. Belts aren't common anymore & besides it wouldn't work at all if there was a belt broken.
Jun 18, 2009 | Whirlpool Washing Machines
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't spin
A common fault on a front loader washing is brushes wearing out in the motor. A general maintance is to check these brushes out about ever two years. Isolate the washing machine from the power. Remove the motor and with a small screw driver lift the brushes of the commutator or just take it down to your local motor rewinder and get him to bench run the motor and test it while you wait. If its had its day look around for a good second hand one. It could be in the electronics but i have seen a motor take the electronics out?? I think its the motor???
Jan 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
150 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
