Question about Nokia e65 Cellular Phone
Blank screen at startup
When i start it up it stays stuck on a blank (not white) screen... also when i load it, it won't show the battery icon... please help me out !
Why won't my compaq presario 1250 load windows?
1 - You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode).
Win 7 - Start > Search type System Restore
XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
2 - Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 11, 2012 | HP Compaq Presario SR1250NX (PJ534AA) PC...
I have a problem installing my Vimicro USB PC Camera 305 on my Windows XP. I start to install but still doesn't work. I try to uninstall but I cant do that from CONTROL PANEL pls tell me how to do that....
It is a pain.
Try the following. Re-run install, insert CD and it should start to load?
The exception is it should come up and say do you wish to uninstall Blah blah . Click Yes. When finished it will want to restart.
Before restart, remove usb webcam. restart.
Go to my poota/programs/and look for the camera file/ it may have been removed in that no problem/ if file is still there/right click/remove. Restart.
Complete restart/then setup CD Webcam again. Sit with it click Ok when asked even not a recognized prog, still click continue.
After completion. Reinsert usb of webcam! wait till it loads, asking silly Q, continue. till finish.
If sucessful, find it in programs if you didn't click for desktop icon?
Startup screen should show small white screen, couple of Q's it can't do something, ignore. You will end up with blank white/black square.
Click menu at top, click devices, dropdown click your cam name, should then open to a larger screen. If you need to alter things, click options.
All this of course if it loads.
Best of British.
Nov 14, 2009 | Computers & Internet
I dropped my g1and its stuck at a blank white screen......
the problem is that your chip is probably cracked and it is not allowing your screen to show up
Oct 06, 2009 | HTC G1 Smartphone
My g1 has a blank white screen screen locked
I dropped my G1, picked it up and it was fine went home a few hours later starting going through my apps it started running weird then it shut off...I took the battery out and put it back in when i did that it vibrated telling me there was life in the battery but the screen stayed blank no G1 intro no android nothing...then screen is not black but a grayish white depending the angle you hold the phone at. I called my carrier we did the reset nothing happened its still stuck at the blank screen? Any help with this?
Sep 25, 2009 | HTC G1 Smartphone
Start-up problem - just stays on apple icon
try putting in the original install disk and do a repair or restore. The notebook should have also come with some diagnostic software. If not, contact Apple and have them hook you up. He can always use the computer at the library..... good luck!
Jun 03, 2009 | Apple Computers & Internet
White screen with Battery Icon never goes away
Dial *#7370# now it will ask restore original device settings,yes,it will ask for password its-12345, your phone will restart, all the data on our phone memory will be deleted,and it will be like when you first bought it,PLEASE DO IT ON YOUR OwN RISK,OR GO YOUR NEAREST NOKIA SERVICE CENTRE. ALL the best
May 20, 2008 | Nokia 6288 Cellular Phone
While playing with PSP it suddenly gets stuck and screen goes blank
check battery, run without the battery, using ac adapter, see if problem persists did you update psp firmware? if so, undo the update, go back to previous firmware version
Aug 26, 2007 | Video Game Consoles & Games
Stupid blank screen on my Craptop
Could be a simple video driver problem, try starting up your laptop in safe mode (Pressing F8 on boot up). If and when screen comes up highlight 'Start Windows in Safe Mode' Next a list of startup drivers etc will stream down the screen and tell you you are starting in safe mode, allow this. If your lcd screen stays on then it's a driver problem, go to add/remove programmes and uninstall driver the driver and restart your laptop. This should then start in VGA mode all icons will be bigger than normal. Either re-install video drivers from setup/restore disk or go to laptops manufacturer website to download drivers. If no screen even in safe mode LCD probably dead. Please rate solution.
Nov 15, 2006 | Syntax ValueBook VT5000 PC Notebook
Nokia e65 Cellular Phone Logo
395 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
