Question about ASUS A8V-VM Motherboard
Cooling fan on a8v-vm se
Can i slow down the cooling fan on my cpu it runs full speed all the time and get obnoxious
    Problem Solver:
  • 36 Answers
The whole colling speed is set properly within the computer so I wouldn't go adjusting that. You could get a different fan similar to the one thats in it, that may be a bit quiter.
Take it to the computer shop and show him them one you thats in it, that is on condition that you are confident about taking it out and putting on a new one in its place.
Make sure you are grounded when you open the computer and wear an ESD (Electo Static Discharge) strap or something. Especially when you are going near the motherboard.
Posted on Dec 11, 2007
Asus A8V-XE motherboard keeps shutting down, just put new power in and it is still doing it
Hi
Kindly see if the CPU fan is working properly. This might be a system shutdown due to overheating components
Hope it helps..
Thanks for reaching Fixya.
Leave comments for further assistance.
Apr 03, 2010 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
My pc audio isnot coming pl do sugest us how to down load model asus A8V - VM SE E2928
http://www.driverstock.com/ASUS-A8V-VM-driver-download/6-9-10211/index.html.only drivers I could find hope this helps.
Mar 12, 2010 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Motherboard flashes when power cord plugged in
I had the same issue with the same mb. The cpu has gone bad. rare, I know, but it happens.
Dec 15, 2009 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Asus motherboard a8v-vm jumper setting motherbord on but cpu fan not ON
You do not use a jumper to run the CPU fan. There will be a small 3 or 4 pin plug near the CPU mount and you can plug the wire from the fan into that plug only. If the one on the motherboard has 3 pins and your plug has 4, you can use it anyway; just be sure the slot on the back of the plug matches the side of the one on the board.
Oct 28, 2009 | ASUS A8V-VM Motherboard
Failed A8V-VM SE Bios update attempt.
ASUS has a marvelous BIOS upgrade utility that runs from Windows,Download the correct one from the ASUS web site
http://support.asus.com/download/download_item.aspx?product=1&model=A8V-VM
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | ASUS A8V-VM Motherboard
ASUS A8V-VM MOBO
To turn your computer off, hold the power button in for 6 to 8 seconds. I would disconnect the fans you installed to see if you are loading your power supply. If you install a video card take it out and in a couple time to clean the contact, with the power off.
Oct 11, 2008 | ASUS A8V-VM Motherboard
Asus a8v-vm se fans always run
Hi jderek4, try this. locate the toggle switch on the back of the power supply. Just find it do not flip it.
Plug the PSU's power cord into the PC. Just as you got a good connection & the PC begains to power up move the toggle switch to it's other position. The PC should power off that very second.
If the PC does not shut off than the PSU is bad. If it did shut down wait a few seconds. Press the cases power on button. The PC should start to boot up. Let it finish loading. Click the start button & choose to shut down windows. The PC should shut off.
Yes? If not than your back to (bad power supply). Swap it out.
Mike
Mar 29, 2008 | ASUS A8V-VM Motherboard
CPU fan races
thanks bigunit12 - as I suspected, no real concern
expect the noise is a pain.
I do think the HS might be marginal and so I shall replace sometime with a higher capacity model, also maybe increase fan flow capacity and add a case hot air extractor fan.
Just to make sure
Jan 07, 2008 | E-Machines T5048 (7136) PC Desktop
ASUS A8V-VM Motherboard Logo
116 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
