Very damp smell - Washing Machines
    President:
  • 1,653 Answers
Make sure there are no leaks from the machine. look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean.
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Posted on Sep 12, 2009
Petrol smell in car
Check all gas lines from your gas tank to the carburetor and see if there are damp spots and if you see any damp spots take your finger and wipe the damp spot and smell. If it smells like gas there probably is a slight leak. even a moist spot of gas will smell big time.
Check all around your gas tank as well. A question i have do you have a clean air filter. If not it might be choking itself to *****.
May 15, 2014 | Suzuki Swift Cars & Trucks
Smelled petrol in car, car do not want to switch on no lights going on
Check all around your gas tank as well. A question i have do you have a clean air filter. If not it might be choking itself to *****.**
Bosch EXXCEL 1400s. Clothes have a horrible damp smell when they come out of the washing machine. have clean and washed out all pipes but sill a damp smell inside machine. What is wrong with it? So bad...
yes,,,,,1 coup of soda crytal
1 coup of any vinegar
1 coup of diswasher salt
put it on 90 degree empty wash..........and see the result.....
my name is khan.
Apr 06, 2011 | Bosch Exxcel WFX 145S Front Load Washer
Bad smell in side car. smells somewhat like a mold or dampness problem.
Check the carpet on the passenger side and see if it is damp or wet. Also, have you noticed white smoke coming from your vents? Does your windshield etc. fog up rather than defrost? If so, you probably have a heater core that is leaking and needs replaced.
Hope this helps! Good luck.
Oct 14, 2009 | 2002 Chevrolet TrailBlazer
Lent is damp dryer takes too long to dry and burning smell
Your burning smell might just be lint which has been loosened by you, getting onto the dryer's heating element. If this is the case, the smell should not last long, nor will it damage the dryer.
Sep 10, 2009 | Dryers
Kenmore 70 series electric dryer. Clothes are
most common reason for this would be clogged vent...check all the way in and out!
Mar 16, 2009 | Dryers
Anti-freeze smell
Hi it could be a leaking heater core matix, Do the foot wells get damp at any time too, Hope this helps
Dec 11, 2008 | 1997 Pontiac Grand Am
Damp smell
do a cycle and put a pack of unsweetened kool-aid lemonade flavor only in with it, this also works in diswashers...
Aug 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Clothes Smell Musty and Damp
It sounds like a build up of washing residue. Clean inside the door seal and do a very hot wash with a bit of washing powder and no clothes. Repeat this once a week until smell has gone.
Oct 28, 2007 | Hotpoint WMA30 Front Load Washer
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
