Question about Leviton (102-5G108-RW5)
I have an outside spot light with a motion detector controlled by an inside switch. I want to change outside fixture & install dimmer switch in place of wall switch. I removed outside fixture. There are 3 black wires twisted together and cappped. There are 3 white wires, which were attached to the white wire on the fixture & 1 red wire which was attached to black wire on fixture. When I removed the inside wall switch, there were no wires connected to it; it was a dummy. Inside the switch wall box there are 3 black wires twisted together and capped, 3 white wires twisted together & capped, & 1 red wire capped. How do I connect my dimmer, which has 2 black wires?
  • 53 Answers
First, let me say that if you're not entirely comfortable doing high voltage electrical work, you might want to call an electrician. It's not impossible for you to get hurt or killed or burn down your house. At least be sure to turn of the circuit breaker while you're working on it.
The blacks and whites twisted together are passing through power to other parts of your premises and are always on, so be sure to keep them twisted together. The red is the one that will take power from your light switch and send it to your light fixture.
At the fixture, connect the white to white and red to black, the same as before. At the light switch, connect the black to one side of the switch and the red to the other. When you turn on the switch, it will permit power from the black to travel down the red to the fixture, and from the fixture, the circuit will be completed through the white.
Posted on Sep 12, 2009
No power from switch to light fixture
I'm an electrician and can help you with this problem. Assuming that this dimmer was installed correctly because it had been functioning properly earlier, the short answer is that the switch has failed.
Dimmer switches are solid state devices, not unlike a modern stereo receiver. Like the receiver, it uses components called transistors and rectifiers to control power that can and do eventually fail. Installing lamps with a total wattage greater than the dimmer is designed to operate will cause it to fail prematurely. Most dimmers are rated for 600 watts, unless marked otherwise. Dimmers are used to control incandescent lamps (those with a filament - unless a compact fluorescent lamp package states it can be dimmed) only. Dimmers are not suited to control the speed of a motor (as is often found in the case of a ceiling paddle fan / light fixture). Use of them in this way creates excessive heat at the motor that can cause a fire.
If you are trying to use the dimmer in these conditions detailed above, it will be a cause for premature failure. Likewise, accidental shorting of the output of the dimmer will cause it to fail instantly.
You will likely need to replace the switch with a dimmer or standard toggle switch to gain control of the load again. If after correcting an excessive wattage load or removing a motor from the output of the switch - and trying a dimmer again, be sure to shut the power to the switch off before wiring and follow the instructions.
If you are installing this dimmer to replace and existing switch or dimmer, please provide more details including the switch manufacturer's name and model, the type and size of load being controlled, number of wires, etc.
I hope this helps & good luck
Apr 28, 2012 | Electrical Supplies
We have the slider lutron dual fan control/light dimmer single pole switch and need to install it to work with our fan/light combo which also operates with a remote. How do you install the combo switch? We...
I don't think you can do what you are trying. The fan & light are on one circuit. Probably, originally, there was only a light fixture there. The fan/light is on a single circuit and the remote does the controlling of both units.
Now, you are trying to install a fan control and light dimmer but you don't have wiring for each separately.
You might be able to use one of the dimmer controls to adjust the output to the fan/light combination, but you can't control them individually, if I understand your wiring.
Gary
Dec 19, 2010 | Slider Lutron: Dual Fan Control / Light...
I have installed (or tried to) three different Leviton PR 180s in my front hall. All operated the 23 watt fluorescent bulb in the fixture satisfactorily, but were not affected by the ambient light; that...
The Leviton PR180 is a motion detector, or occupancy detector.
It senses infrared heat from a person's body.
I am looking at the manual from Leviton.
Maybe this will help:
There is a small adjustment screw under the wallplate where you can adjust light sensitivity.
Use fingernail or small screwdriver.
Turn control towards the "-" sign and lights will turn on in 'less lighting conditions'
I will be here for a few more hours.
Add a comment and I will help further is needed
Nov 05, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
WHERE CAN I FIND REPLACEMENT PLASTIC MOTION SHIELDS FOR MY OUTDOOR LIGHT, 248 617
To be honest with you... you can find new energy efficient, three lamp, two light level, motion with photo controlled security fixtures for $30.00 at Costco, Home Depot or Lowes. Where a new motion detector will cost $10.00 and takes about as much work to change. The lens itself will be difficult to find and is not absolutely necessary. Good Luck!
Douglas
Oct 23, 2010 | Home
I have two outside motion detector lights acting weard
I don't know what type of sensor you have , but most have a sensitivity and range adjustment on them, I would turn one or both down and see if that helps. Also make sure the sensors are not aimed at each other, the heat from the bulbs on the other fixture can cause the opposite fixture to trigger on & vise- versa. Good Luck
Jul 04, 2010 | Home
How to install a dimmer switch
This is a 3-way switch, made to control a light fixture that is also controlled by another switch in a different location. A typical example is a ceiling light fixture installed in an upstairs hallway, which could be controlled by switches at both top and bottom of the staircase.
The green wire in your switch is the ground connection, and joins to the green insulated or bare copper ground wire in the switch box. The red wire is the common connection. It connects either to the incoming AC hot wire from the electric panel, or to the hot terminal of the light fixture, depending on the switch location. The two black wires are traveller connections. They connect to the traveller terminals of the other 3-way switch.
If you purchased this switch as a replacement for a regular single-pole toggle switch or dimmer switch - one that controls a light from a single location only - then this isn't what you need and you can't use it. You'll know if you have a single-pole switch because it will have only three wires or screw connections. Return it and get a single-pole.
To install this as a replacement for a 3-way toggle switch or dimmer, connect the red wire to the wire going to the common terminal of the original switch. This will be a black- or brass-colored screw on a toggle switch, or the different-colored (not green, that's ground) wire on a dimmer. The black wires connect to the wires that go to the traveller screws (copper-colored) on a toggle switch, or the same-colored wires on a dimmer. It doesn't matter which traveller wire connects to which.
Note that if you're using a 3-way dimmer, only one of the switches can be a dimmer. The other switch has to be a plain old 3-way toggle.
Apr 08, 2010 | Pass & Seymour / Legrand D703P Harmony...
How to wire a cooper industries 6107 3-way motion detector switch
I opened the box and traced the lines to see which are connected
when the switch is turned on and I left the red wire disconnected.
Jan 28, 2010 | Cooper Wiring Devices Motion Sensing...
My motion detector switch stays on, lights won't turn off. How do I reset the switch?
Hi MBE,
Most motion detectors have sensitivity and duration adjustments. Others have test modes.
Since the model is not specified, I can't tell you where to look.
You will know it when you see it though.
Best regards
Mike
Dec 05, 2009 | Pass & Seymour Electrical Supplies
Electrical hook up for 2 motion detector lights so both lights operate when either detector is activated (dual master system)
yu can't do it with off the shelf detector. Sine the detector is single input.
you need serial and parallel input to the device.
you need to get commercial detector that haev serial and parallel input to the detector.
Dec 15, 2008 | Solar Motion Security Light Conversion...
Leviton (102-5G108-RW5) Logo
97 people viewed this question
Top Leviton Computers & Internet Experts
vimal
vimal
Ali Asghar Khambati
Ali Asghar Khambati
ashburton
Are you a Leviton Computer and Internet Expert? Answer questions, earn points and help others
