Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
I want to purchase an additiional memory card for a trip. Looking at SDHC 8GB memory card and it indicates "Card is compatible with SDHC Devices only" I don't know what this means. Are they compatible? Thanks
    Scholar:
  • 44 Answers
Sorry but the sdhc card wont work for that model... that type of mem card only works for compact cameras ( think higher/latest cam models).. so dont buy it, you will only get errors when u use it for ur camera and even if u format it over and over put it in put it out in out, still wont work
sdhc- high capacity memory card
Posted on Sep 12, 2009
Samsung s1030 digital camera keep showing memory full but have inserted new sdhc card how do i clear this as i cannot take any pics
Clear it by putting in a compatible memory card. The S1030 works with SD cards. Your 8GB SDHC card in not compatible. You need to use SD cards, 2GB and smaller.
Sep 08, 2012 | Samsung S1030 Digital Camera
The only sd card i can find locally is an 8gb marked PNY SD HC it says on the packaging that this is new technology and only compatible with SD HC host devices. Is this card suitable for the Vivitar...
To be correct, the 8GB card is not an SD card but an SDHC card.
The 925DVR can use both SD and SDHC cards, up to 32GB in size. There should be no problems with the PNY card.
May 08, 2011 | Vivitar Cameras
I just inserted a 8 MB card in and the camera says "Memory card needs formatting" I click continue, then it says "Formatting will delete everything on the memory card", no problem, it's a new card so I...
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
Sep 30, 2010 | Kodak EasyShare DX4530 Digital Camera
I just purchased a sandisk sdhc card 8gb memory card.how do i my camera says it is the wrong format.press ok and it will format it....i pressed the ok button and it says unable to format.can you help.
The problem is that you're using an incompatible memory card.
Your camera is designed to use SD memory cards up to a maximum 2GB capacity. Click on this link for the user manual and look at the specification on page 43 under the heading "storage".
You're trying to use an 8GB SDHC: not only is the capacity far too large for your camera to handle, but it's a later technical standard which your camera does not have the hardware for. SD and SDHC cards may look the same, but are very different "under the skin". SDHC compliant devices are backwards compatible with earlier SD cards, but SD devices like your camera cannot be updated to use SDHC cards.
Your only fix is to replace the SDHC card with an SD card of no greater than 2GB capacity.
Please take a moment to rate my answer.
Jul 30, 2010 | HP Photosmart M525 Digital Camera
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
DVR 518 question regarding sd card compatibility;- will the product accept a SDHC card to 8gb I have difficulty in getting a standard SD card
The manual is not very precise but you cannot get normal SD cards that go to up 8gb, the highest is 2gb.
When they say 8gb they must mean SDHC.
Hope this helps.
Mar 19, 2010 | Vivitar DVR518 Camcorder
Inserting either a 4Gb or 8Gb SD card results in a "Memory Card Error".
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Dec 27, 2009 | Pentax Optio S4 Digital Camera
I only get 2minutes of video time after adding a 8GB SDHC card
There is small button on the card which needs to be unlocked so that the card is ready for recording. Also make sure you have changed the media from internal memory to Card in the settings section.
Thanks
Jan 25, 2009 | Cameras
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
153 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
